SONA/CITIZEN
33 minutes ago, berniethebolt said:
does anyone know which citizen model the hmt sona is based?
I don't think that HMT based any of their watch models on any Citizen models as such.
However, I do know that HMT used the Citizen Cal:0201, made under licence and re-branded, in a lot of their 17J manual wind watches.
Post a pic of the movement and I may be able to identify it.
OK MARC.DID YOU GET MY PHOTOS?
Bernie,
comparing your pics with my own Ciitizen 0201 it looks as though there are some minor differences in the shape of the plates and machined recesses, but all the key reference points look the same.
These are Citizen 0201 for comparison;
P1060273.thumb.JPG.c46dfc2f5fb6e512472675d83d0d5c79.JPGP1060277.thumb.JPG.3962d864935e72b56ea5203ec87fe751.JPG
The part you are after is the hour wheel. If you measure the dimensions of yours I can tell you how they compare with the Citizen.
OK, I'm not sure that the hour wheels are interchangable then. On my Citizen 0201's the hour wheel is 6.55mm diameter (32 teeth), with a 1.53mm OD pipe, 1.27mm tall. I have also just opened up my HMT Jawan which does have the HMT version of the 0201 movement and the plates are identical to the Citizen, so I'm not at all sure.
As for the keyless works, have you had them apart? It looks to me that the parts I've edged in blue might be in upside down. If you flip them over and add the missing parts I think they will look the same.
5a33f0d588eb3_2017-12-1515_42_41.thumb.jpg.ae5a04598a4970d64c45197cf4755e56.jpg.29114f152901c06b3960cb2bf4312c8f.jpg
Slightly clearer
Edited by Marc
clearer pic
ok, this link shows a HMT movement with the same shape plates as yours;
http://jayprashanth.blogspot.co.uk/2008/02/indian-mechanical-watches.html
and identifies it as a HMT 0231
Ranfft;
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk&HMT_0231
says that the 0231 is a copy of the Citizen 1802 BUT.... the pic he shows has the same shape plates as my 0201, and the dial side is totally different, so somewhat confusing.
one posibility is that HMT used different shaped plates at different times for the same calibre and it is a 0201, can you remeasure your hour wheel, make sure that the calipers are properly zeroed first just to be sure.
One thing that Ranfft does say is that the cal number may be on the case back. Also have a good look over the main plate and make sure that there are no numbers there.
OK,ON THE CASE BACK IT DOES SAY 0231.i get around 6.40 dia.the other meas.are similar but like i said my calipers are playing up.as for the keyless works you are probably right as i copied the routine off my phone camera,so that can be soon sorted.thanks for that.the hour wheel would probably have had 32 teeth before i sheared them off as i counted the remainder and the gap would allow for those missing!B.
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring it is still good. II am awaiting the replacement setting, and I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
