My First Strip Down - Helvetia
PhilB
Thanks guys, I have almost no idea what most of the parts do.
What should I do before re-assembly?
I have it in mind just to put it back together.
Maybe I should buy some oil or give it a clean and new main spring.
The movement was working before dismantling but stopping intermittently.
Would it be frowned upon if I just attempted to rebuild it without any servicing on my first attempt?
Given that you are just starting out in this horological hobby and probably don't have specialised cleaning equipment, thoroughly wash the parts in lighter fuel before re-assembly and lubrication. You will have to purchase watch oil, oilers and grease to progress with your task. Make a point of watching Mark's videos where he describes in detail how to lubricate a watch. Oil the pinions and jewels only, nit the gears, and remember too little oil will cause less problems than too much.
I forgot to say that given the inter taint problem that you had, you will probably nor require a new spring.
Edited by Geo
I believe that for starters it would be OK to use toothpicks (pegwood is customary but maybe this time we can look the other way :)  ) and carefully peg every jewel before cleaning. Inspect them and determine if they are not cracked or chipped. Maybe after cleaning and lubing the problem goes away...or it may need a part replacement?
I've removed the barrel bridge to show the mainspring barrel and what I think is called the great wheel(?)
Finally I turn the movement back over and remove the winding mechanism and it's finished.
I'm going to leave the main barrel closed this time, give the watch a clean and start rebuilding but I'll need some supplies first.
I'll use a toothpick as suggested and source some basic watch oil. I have some lighter fluid but really need to study what I can and can't put in it to clean.
Am I correct in thinking I shouldn't put pieces with jewels in the ligher fluid because of the glue or have I got two pieced of info mixed up?
I have a good look at the bare parts and noticed this hook. There are two of these on each side of the movement.
During the dismantling I never touched them, what are they for?
Also there is a stamp H873 - I expect this is the movement no.?
Now I can see the new pictures! Excellent documentation PhilB! The toothpick is for pegging, you still need an oiler to oil the movement. I suggest the smallest one, usually the black Bergeon which is not to expensive (for a change).
They hold the dial in place, you should have pushed them outwards to release the dial. Before fitting the dial hinge them outwards, position the dial, then press them back in to grip the pins.
The dial just clips on with two pegs, I can't see how these hold it on tbh.
Thanks, I'll have to gather a list of things need to get it back together and place an order.
Oil and oiler I think.
I'd like a x4 + x10 magnifier.   I'm using a x20 and it's a bit too close.
Look for my video on how to service a quartz watch. It has the same kind of dial fittings.
Fantastic write-up Phil ... well done!
As for being concerned about parts falling out un-noticed, as you said "Photos" ... I take HEAPS of them for just that reason.  Even though I'm getting much better at identifying each part, I never get complacent about taking reference photos, and on more than one occasion it has been invaluable for identifying the correct location for springs and gears.
Also Phil, one thing that I also do is download the Tech Document, and name each part as I remove it, verbally to myself.  I also make a point of naming each part properly in my write-ups to reinforce it in my brain.  It may sound a little silly, but for me, it has fast tracked me remembering all the parts of a movement and where they go.
Legarm, on 04 Sept 2014 - 3:46 PM, said:
I also name the parts, most are called Dave, so I get really confused......... :unsure:
Geo, on 04 Sept 2014 - 5:34 PM, said:
I've come across a few whatsits and the the thingamajigs in chronographs!
ROFL!!  :lol:
Hello guys
I want to put this back together, and so have watched Marks videos
How to service a mechanical watch. Part 2 and 3.
Mark uses  Moebious 9501 Grease and Moebious D5 Oil.
I don't want to spend too much on my first build so is there something cheaper?
Phil
Do you want to put it back together and make sure it works, then take it apart again and so on... ? Or do you want to put it back together to wear it ?
If it's for practice, I say use basic oil to practice oiling properly, to make sure it's lubricated enough to run a bit, but don't use it for long periods of time. I'm probably going to get smacked for saying this....
If it's for good, then, you have to invest I'm afraid... And it might seem expensive, but this little tiny container of oil will last a looooooonnnng time. Do you have an oiler yet ?
How did you end up cleaning it btw ?
I used this oil for my first couple of watches, because l didn't know if I would be any good at watch repair. That was about three years ago and they are still running OK and keeping good time. I now use Mobeous oil.
Hello guys - I've started rebuilding this movement but I'm having some difficulty replacing this cover plate.
As far as I can see, I need to fit the plate while making sure the top stems of these 4 cogs are correctly fitting in their jewels.
The first wheel on the left (great wheel) is completely hidden under the cover plate making it impossible to align.
Any tips to improve my chances?
I haven't installed the crown wheel and winding mechanism.
Remove the balance wheel and escapement lever, these should be fitted last. This will now allow you to fit the main bridge more easily, and also allow you to see if everything is running freely. Once you have achieved that, fit the escapement lever and do not oil the jewels that it oscillates in. Now wind the watch 1-2 turns and check that the escapement levers flicks sharply from side to side by gently pushing it with a dry oiler or tooth pick.
If all is well, fit the balance wheel. Make sure that you position the balance jewel correctly in regard to where the the end of the lever. Looking down on the lever, if it lying to the right, ensure that the balance jewel is even further to the right when you drop the balance into position. Vice versa if the lever is lying to the left. As you turn the balance cock into the correct position the watch should start running.
Agreed - as a general rule you should never fit the train wheels after the escapement is in place - you will find it very hard to locate the escape wheel as it will keep fouling the pallets - and you could even chip the pallet jewels.
Take the balance and pallets back off then you will be able to fit the train bridge with not problems and importantly check the free running of the train as Geo said.
The wheels are correctly orientated as far as I can see. But I would also remove the ratchet wheel which will give you better access to locate the pivots.
Good job so far! :)
    • Doesn’t really work for this, really it needs to be an invite only platform with good moderation. Full disclosure I spent a fair amount of my career as an IT/Network security consultant and am very touchy about what I may release on ‘tinterwebs.   Tom
    • A better solution than having a list that will be compromised for spam would be to have a contact email. In other words an emergency email or even for that matter as separate website for emergency use as opposed to we all list out our names and emails and get spammed to death as there would be almost no way to protect that from bad people.
    • Thanks for the various replies. Here are answers to some of the questions/suggestions  switching the winding shafts doesn’t work because the no7 I need is significantly larger than the bore of the no6. i do have a set of chinese winders too, but as noted they’re movement specific and none fit the bill here.  I don’t want to replace the mainspring a)because I like to keep things as original as possible and b)where I live it’s tough to import parts so i have to wait long periods between supplies   so in conclusion I expect to be handwinding the spring this weekend
    • From the photo the pallet arm looks as if it has been tampered with the edges are not nice and straight this can cause problems on the banking pins.
    • Update, I discovered that I could change the mainspring by removing the arbor and sliding it out from between the front and back plates. So I put a new mainspring in. This it what I  get over a 7 day period After winding                                          amplitude is 1 1/2 turns plus a few degrees.        ie just over 1 1/2 turns. 1 day after winding     gained 1 sec      no amplitude check. 2 days after winding   gained 1 sec      amplitude 1 1/2 turns        i.e. it lost the few extra degrees 3 days afer winding    gained 3 sec     no amplitude check 4 days after winding   gained 5 sec     amplitude 1 1/2 turns        i.e. unchanged 5 days after winding   gained 7 sec     no amplitude check 6 days after winding   gained 16sec    amplitude just over 1 1/4 turns 7 days after winding   gained 24sec   amplitude 1 1/4 turns. From  Based on video inspection, I am getting full pallet lock. So, my data seems to be at odds with the statement "swing of a balance wheel has nothing to do with the rate". However, I have noticed the banking posts are not controlling the lever position on the right side.  I may have some work to do here.
