Eterna 629 project
rogart63
This is so stupid project that i started. I service a Eterna 629 with bad balance. I can't find a new one. And found a very similar balance from a 9,75 ligne watch  that is for 18000 hz has the hairspring from the right side. bla.bla bla . But one problem is that the impulse stone is to large. Won't go down into the pallet fork. If i can find a roller table with the right size impuls do you think it could work. Not after cosc working watch but would be nice if it would run okay within a minute a day.
Edited by rogart63
So is this the same watch found in this discussion?
https://www.watchrepairtalk.com/topic/7545-eterna-629/
Then the picture of the movement you have in that discussion where did you find the model number because I'm not seeing it in your picture?
Then picture of the dial side with the setting parts and the diameter of the movement would be helpful to see if we can figure out what the movement really is.
11 hours ago, StuartBaker104 said:
According to Jules Borel, an Eterna 629 is equivalent to an ETA 2892-2, but thats a high beat automatic, so clearly not the right match. Are you certain on the calibre?
Yepp . Old one from the 1930 ish.  I am sure it's 629 . Looks like this with my balance on. have screwed it down as the impulse jewel does work. DSC09096.thumb.JPG.55080e2c154f9abbaa1d5168582849c7.JPGDSC09097.thumb.JPG.9f48015ae9eca0e544492357b969a7f7.JPG
Edited by rogart63
So in your pictures where exactly did you find the 629? Not that I don't believe you it's just that when I Google and look at my references I can't find a 629 and I'm not seeing it in your pictures?
Then there's something called a fingerprint system founded a variety of older material reference guides. To use the fingerprint system you need the diameter of  the movement  and the setting parts found on the dial side. The setting parts that are conveniently missing from your photograph. So if you could lay those out on a piece of paper and get a image of those I can look in the book and see if I can figure out what it is.
Then one of the reasons I ask about the number is there can be a lot of numbers on a watch none of which necessarily are the model number.
    • Hi John, The most important parameter of the spring is the thickness. The lenght is something that one would not consider as obligatory, as relatively big variations will not affect anything in significant way. The barrel size is related to the barrel and has nothing to do with the spring. Yes, the spring is designed to work in a barrel and the size of the barrel matters, but let this parameter be chosen by the movement manyfacturer, not by the sping manyfacturer who doesn't have idea in what kind of movement the spring will work. Sometimes the washer in which the spring arrives will be bigger than the barrel and there will be no way to just push the spring in the barrel and be happy. Well, if this is a problem for somebody, then probably He is a person with to many problems that will be verry hard to help to in any way. By the way, why You are changing the spring? Is the old one broken?
    • Lets give it to the end of this month to get all the votes in, then we can call it?
    • OK, I have created a solution to the above, I have made a fake protonmail account, if you PM me I can send you the password, just click on the contact link and enter your information, this should be as secure as it gets:   Website:     Link Login: email as highlighted in above screenshot WRTArk    @   Proton.    me Password: ..........PM me and I'll let you know   Only intend to use the contacts function, not the email or anything else - we are all grown ups, please act responsibly.
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
