New Member from NY
Hi all
I'm Matt from NYC. I have been collecting watches for the last few years but, recently decided I wanted to take it a step further.  I find watch movements fascinating. I have been researching the skills, resources, and tools required to enter into the world of watchmaking and repair.   Recently I acquired some basic tools and am excited to start Mark's course.   I was wondering if the Swiss Made Sellita 210-1 movement is appropriate for this course.
Hi Matt, Welcome. I think that almost any modern watch movement would be OK. I have never done Marks courses but I have no doubt that his courses are 1st. class.  His knowledge and ability is superlative. I have another expensive watch to sort out for a friend who cannot afford the Big Boys.  With Marks  video`s and my copy of "Practical Watch Repairing" I feel quite confident of a successful result. If I were younger (76 now) I would certainly study with Mark`s courses. Best regards,  Mike.
    • Thanks Geotex, From what I can see the keyless works on mine is completely different to those in the photo, I had a bit of a Google and it looks like it's called a rocking bar?? I can't seem to find a single match online though. As far as the setting lever screw goes, you've just explained what I'm doing wrong and why it was probably left out in the first place. It needs to go in before the bridge 🙃. That's why the hole isn't big enough because it's designed to be smaller to stop the screw falling out until the bridge is removed. Thank you for that! I'll remove the bridge tonight and get it refit.
    • The term "digital transistor" is not a term of art--at least in the modern world.  A lifetime ago, there was such a thing as DTL (Diode Transistor Logic).  Resistors were involved, but I am not aware that they were ever integrated into the transistor package.
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
