Adjusting Nut for Boley Leinen Lathe
jdrichard
I set up my new Boley Leinen Reform lathe but the adjusting nut for the spindle does not lock as it is not a split nut and has no way of locking. I have included the photos. Would you know where one could get ine of these nuts?
2d688f96903d37721e564044e5b38326.jpg763f0dffeda9da145a01ab4c0f62b28b.jpg6ca0f712d7cc22edc4f99d7cedc6af91.jpg5b6509b7f0290f837f664e2d6003297b.jpg57cd5d7cf5a4bbd594d4126c8ddd8b2f.jpgc7c701465476c789622de155105fe662.jpg9d5f015928eb085dff4bcb9fafc23299.jpg
Sent from Yahoo Mail for iPhone
I'd try to find out what is factory and replicate that, I'll look at mine but I don't want to take it apart.  I have enough machines in pieces strewn across my basement and garage lol.
Making a nut like that is very easy for anyone with a machine shop, just make a drawing and get it made.....but first I'd want to know what about it isn't factory, and if it is factory, why it isn't working
Edited by measuretwice
I agree. It is so hard to find and data on boley leinen reform lathes and what the nut is supposed to be. Probably need a hand from all the resources out there. I have worn out the Google keys on my tablet.
Sent from my GT-N5110 using Tapatalk
JD, you require two thin nuts, one adjusts the end play of the shaft and the other is tightened against the adjuster nut to lock it.  You will require two "C" spanners to me the adjustment.
The nuts should look like these :-
Edited by Geo
Why not split the one you have and compress it slightly if you want to go that way?
I was going to get a nut that matches the one i have and do just that. There is a great fastener store 10 min from my house. Got all the hardware to bolt the lathe and motor to my deske04bf195d510f9612866e2fb82ac56bf.jpg
On close inspection, it looks like the brass cover and the nut have been made as replacements.  The cover, appears to have been split with a hacksaw given that there are what appears to be linear scratching in the slot, and the depth (too shallow) and finish of the the threads do not look right for a machine made by Boley.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
