British military 1917 evaluation wristwatch
wls1971
This popped up on ebay last week as a £50.00 buy it now
During the Great war the British military had been issuing pocket watches to serving personnel and hadn't supplied wristwatches, these where instead bought mainly by officers privately for use at the front lines with wristwatches improving and the introduction of the water resistant cases, unbreakable crystals and radium dials the Trench watch was born and became an item of necessity for serving personnel.
It wasn't until 1917 that the war department purchased the first batches of wristwatches supplied in two forms the first being a classic trench watch of water resistant case, black dial with radium numerals and unbreakable crystal and the second type being a large cased snap back, black dial with radium numerals all had 15 jewel Swiss movements. These watches where purchased for the purpose of evaluation to assess the usefulness of issuing wristwatches to serving personnel.
This watch is of the snap back type and has a unusually large for the period 38mm  case made of nickle, the dial is  black enamel with radium numerals.
All the snap back models have issue numbers that follow the same form a five digit number beginning with a nine followed by a letter M there is also a Broad arrow mark or Pheon crudely stamped on to the back some watches are stamped with two broad arrow marks that touch at the tip this is thought to indicate that the watch had been withdraw from service.
The movement in these large snap back models is the same in all known watches where as in the water resistant 1917 watches there is some variation. The movement is a good quality 15 jewel movement and no one has yet been able to identify who manufactured them there are no identifying marks but there is a brevet patent number on the dial side so it may be possible to trace that and establish who made the movements.
No one is sure what branch of the armed forces these snap back watches where issued to but it cant have been to front line personnel because having no water resistance would have rendered them pretty useless in the field, many have speculated that they could have been issued to the flying corps because the design mirrors quite closely the pocket watches already issued to them at the time, these snap back models where only issued in 1917 and withdraw from service shortly after, but the water resistant watch became a regular issue watch there after IMG_2628.thumb.JPG.351ef07a95fe2f8794a765e1b85db90d.JPG
It is however an interesting footnote in the development of the military wristwatch and is amongst the  first officially issued and stamped British military watches of the Great War.
Edited by wls1971
25 minutes ago, Geo said:
Wis, I think it may be an Electa movement
 I will have to search through my movement catalogues and see if I can get a dial side match on the setting lever bridge I've already tried Bestfit and found no match I shall try and look for a dial side photo of some Gallet Electra movements that will tell me for sure as there are some similarities on the bridges.
  • 3 years later...
Have you got the patent number, I can look it up?
Thanks. Carl.
Also, the watch below has what I am sure is a smaller version of the same movement:
This movement is a Fontainemelon but I would have thought if the mystery movement was one it might have been identified. There are so many similarities though I would go with Fontainemelon if I had to choose.
I've done a comparison. If you ignore the bridges and plates and look at the screw, pivot and wheel placement from the FHF to the left and then compare to the finish of the wheels and the movement of the FHF to the right it looks like a match to me.
A picture of the dial side would clinch it.
Edited by Penfold
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
