I've come across this online site that sell movements without the face or the dials or anything. It is the online shop for a physical shop that is close to me but I was wondering what is the reason behind selling these movements like this? Is it to build your own watch by choosing a face and the hands and all that or is it to practice with. Some clearer info would be appreciated
You could do that but in most cases its to replace an existing movement in a watch because quite often that is the most economical thing to do with quartz movements especially total replacement of the movement is often the cheapest and quickest option than expending the time and effort to fix an existing movement.
Most of these movements are quartz. When repairing a quartz watch, a new movement is often the most cost effective fix. The same can be true of inexpensive mechanical watches. That’s why most new bare movements are bought.
You could as you suggest build your own watch, and some folks will rescue a dead mechanical watch with a quartz movement.
Neil
Aaaah that makes more sense. The odds of finding the exact movement for the one you need might be a bit slim? I've also wondered about the watch balance wheel. Do they all differ depending on the movement they are being used in or are the more basic mechanical watches using a standard type of balance wheel?
Thanks for the info so far. I'm most likely going to asking questions as they come up.
Interesting and I see where you're coming from but interchangeable parts does not denote cheapness, in fact it's the opposite. The initial set up of such machinery would be beyond the financial capabilities of most watchmakers.
Seiko enjoy a high degree of interchangeable parts including balance assemblies which is why they may be so popular with the watch repairer
Sent from my SM-T585 using Tapatalk
11 hours ago, Neileg said:
Balance wheels aren’t really standardised but a dozen quartz movements might cover 90% of the watches you come across.
What diggingstony meant to say is simply that Seiko balances are interchangeable across 7S, 4R, 6R, 70x and may be even older movements. Indeed, a nice point for repairers and tinkerers.
Yes, thankyou [emoji16]
Yes I understood the point. All I meant was that quartz movements are less varied than mechanical watches (on the whole).
Neil
Thank you for all the info. This is really clearing up a lot of different things. Can't wait to start buying all the tools and to start tinkering with various watches and movements.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
