Watchmakers Lathe Speed Pedal
jdrichard
I have been pedal hunting for a few weeks now and have some advise. Could be good advise as well:)
1) Don’t purchase a variable speed pedal from amazon that is from china and claims to be variable. This one looks ok but has only 5 speeds that are set by 5 large bar resistors. Not good for lathe applications.
2) The next pedal is fairly inexpensive (38 bucks) and may work for some, however, i found that all my motors jittered when running. This pedal is based on a small part that controls the speed through either Pulse Code Modulation or some other algorithm that drops the current. This part is the exact one used in hand drills, etc. I think the Company is good and responsive, just think that this component of the foot pedal is low end. I also think the plunger will degrade quickly with constant use. Part is from a Japanese controller company.
3) Sewing machine pedal. This is great if you use a sewing machine AC motor. Need to ti make sure that there was not another controller within the sewing machine between the pedal and the motor.
4) BEST Controller is the Lucas #9 Lowboy. This controller is a high quality build all metal with a low pedal that will not strain your foot. Not sure what the electronics are, but it has great linear control and feels like butter. The cost is only $50 bucks US ($100 canadian for me with $25 shipping). A great deal for the quality of the build.8d9aa7aa3c0b8e6e4471865e4c1c341c.jpg
Update on the world of foot controllers. Turns out that the electronics in the lowboy are the same as in the Foredom pedal. On the sewing machine motors, they both work ok but do have a little PCM jitter. The router speed controller i have is smooth and has a circuit board with a knob rheostat. This is not a pedal but works extremely well if you want constant speed.17cf6be4c86fe7f057c64cb647d289e0.jpg
So i must apologize to the Foredom folks as they all seem to use the same plunger Japan component in the foot pedals. I will now investigate smoothing out the power signal to the motors after the foot controller.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
