Date jumper spring
Chopin
I just lost the date jumper spring from a Seiko 4006 and I wanted to know if it's possible to make one out of guitar strings and if possible which thickness should I use ? The thin e string or the b string ?
Pic below for reference. i'm thinking it's around 0,3-0,4mm thick. Would it be safe to make it on my own ? I don't want to buy one...
Think that it's flat in profile. Had one i measured on and it was 0,12 mm . But there seem to be something strange today as everything i touch seem to go into orbit. It went into my parts drawer . So it's here somewhere. Should be fine with a round spring as long as it put some pressure on the click.
Darn it I had just placed an order a few days ago on Cousins. I wonder if mine could be found in there... I have a few of these shepherd's hooks as they seem to be called but none fits or can be modified, I think...
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
