Replacement glass for Omega
The one on eBay doesn't look like a screw down crown. Is the original?
3135 Clones are below 200 bucks. I payed €87,- for a good one from Ali to get practice for my genuine Oyster Perpetual. Servicing this clone, I could perfectly follow the Rolex documentation.
Since the back can be removed, I see no reason for a split stem. -
The balance is not in original condition for sure, but this doesn't mean the roller is not original (or doesn't mean it is original as well). I would advice to check how the roller interacts with the pallet fork and how the balance sits in the movement and if it is positioned OK with the bearing stones, pallet fork cock and center wheel. So, just glue in some way the roller and see what You have... The next thing (if everything seems OK) is the hairspring and free oscillations test, and confirming if the oscillation frequency is correct.
