I guess that this is a bit of a dumb question, but that never stops me. I often encounter loose press-fitting case parts. Before I start "experimenting", how do the wise deal with this problem?
Roy
Roy
Good question . Have a Candino that has a loose fitting caseback . Not sure how i shall fit it? The gasket is also missing.
Yes indeed, gaskets are a factor. However I'm looking at a couple of watches where adding a gasket would, I suspect, make the fit even worse as there appears to be no extra clearance available to accommodate one and the pressure required to eject the part is already very slight.
there are ways to repair lose case parts.   some jewelers are "silversmiths" (tinkers).   this forum should have one.   don't use "trial and error"  on a valuable silver case.  vinn
Experienced this also with some older watches....gaskets can do the trick...maybe the casebacks are misformed a bit so they don't fit exactly?
