I have some shellac flakes that are likely quite old, came from a long retired old boy's collection.  I tried using some unsuccessfully with wax chuck and could not get it to stick properly.  I know the woodworkers when dissolving shellac to use as a finish consider it to have a shelf life of a few years.  My question is, is the same true for it as a cement?  Or does it last forever and I'm doing something wrong?
Edited by measuretwice
I had a small box of shellac handed down to me and it was donkey’s years old. I used the flakes for setting watch pallet stones and the pallet stones on French clocks with visible escapements. I never had any problem with what I had.
The object the you should stick to the wax chuck needs to be warm  also as well as the chuck. If you just melts the shellac and stick it to the chuck it will fall of.
Thanks for the help.  I was trying to melt by warming the chuck.   Its suppose to melt at 100C, I wasn't measuring the temp, but think it was much higher before it started to melt.  New isn't that expensive so I will get some - if not for age, just to be sure its actually shellac.   Given the difficulty and you guys saying there isn't a shelf life, I'm questioning whether it is shellac.  Brown flakes in a watchmakers bench .....looked like shellac lol
The de-waxed shellac flakes do have a lifespan. I've used some OLD shellac (that came from Prof. Torrens workshop) It was/is very good.. so maybe it's the storage conditions that matter?
So it looks like I was I a bit dense on this whole affair, what I had tried to use could not have been shellac....although it look like it.  Comparing them side by side, the real stuff was a bit more translucent.   Anyway, with proper shellac fixing to a chuck was quite easy.  Its a screw with a shoulder on which a wheel turns, out of an alarm mechanism in a pocket watch.  It had a bit of rust and needed a clean up (watch is of low quality, the whole exercise is for learning).  I first cleaned up the top of the screw (it had some damage and rust) so it would sit true on the face of the chuck.  Centreing is a neat process that took a couple of tries to get onto - after cementing I held an alcohol lamp under things and with a small piece of brass wire nudge it concentric - with just enough heat to make the shellac flow, but not so much that the piece falls off.  Two false starts, fortunately I found the right balance before losing the part.  A bit of heat detaches the screw from the chuck and the remaining wax was removed by boiling the screw in alcohol - done in a small test tube over an alcohol flame.
Overall (once I used shellac) it was a  fairly easy process and a convenient way to chuck small items.  I've been polishing and cleaning parts on the watch with the hope of getting it running.  The main thing needing repair is that the barrel arbor is broken - that's next!
Screw original condition
after nudging into place, things are running true
After a bit of burnishing then polishing
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
