Hi guys, been awhile I know, another question, I need a new mainspring for a nice old cylinder fob watch im working on,
My springs dimensions are as follows, 1.29mm height x 0.16mm thick x 300 mm length, barrel diameter is 11.31mm
On cousins the closest that my untrained brain can find is 1.25 x .115 x 340 now I know these measurements are abit off from my original ones but could someone please tell me what measurements are allowable to change so you can get a spring as close as possible if an exact replacement is not available?
I can hazard a guess that I could drop a little on height as I have done so before after a kind member here pointed me in the correct direction for a new spring once before, but before I continue to ask the same quest over and over I need to learn this stuff once and for all so I don't have to keep annoying you all.
cheers guys
Interesting situation. I'm no expert by any means but it looks like you should give it a shot. The replacement spring may be a touch underpowering but it's also longer, so it may work to fit it in the barrel. I figure the power difference would be low enough that you could compensate by regulating the hairspring.
The alternative is a thicker hairspring which would over power a bit which is find unless the movement knocks.
Let us know how it turns out!
One thing to remember a third of the barrel too be taken up by the barrel arbor a third by the spring and the other third left for space.
With many of these old pocket watches, you will never find the exact match. It is better to be a little weaker then to strong, providing it will run for 30 hours unless it is of 8 day duration.
Gents many thanks for the help, and yes Stuart it was you before, so again cheers, oldhippy thank you, away I go with some new found knowledge, ill let you know how I get on.
Thickness 0,16 is much too strong, 0,115 much too weak.
Hight and length are no critical sizes, but thickness should be right. My calculator says thickness  0,135 ... 0,14  length 350 ... 360.
I will post a little program for this and other calculations soon.
Frank
Manyy thanks guys, sorry was away with work again and haven't been online for a couple of days let alone at the bench trying to solve the mainspring problem, will hopefully be on top of this in the next few days and have one on order and soon fitted back in the movement
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
