Whilst I'm here I'd like to ask what I anticipate will be regarded as a stupid question. Stupid? Well yes but it occurs to me so often that I feel obliged to flush it away or act on it.p.
I've attempted two total dismantle / clean / re-assemble jobs, both on disposable WW1 three finger bridge movements. The first had numerous cracked and broken jewels however I managed to re-assemble it, including re-fitting the balance cock assembly, as an exercise. The second not so good. I managed to destroy the hairspring with the balance cock handled intact. I simply couldn't line up the stem and the thing got away once too often. The prospect of assembling a single bridge that has three jewels is something I'm not sure I could ever manage, and the first attempt at the balance was probably a fluke.
What I was wondering is whether a movement could be US cleaned (using the proper sequence of fluids) with only the barrel bridge, keyless work and balance cock removed - perhaps slackening the bridge screws by half a turn or so to enable a little separation and the gunk to dissolve.
I'd hoped that doing basic cleaning on relatively simple WW1 era men's watches might be achievable, but I'm beginning to think it may be beyond me.
Roy
Practice mate thats all it takes, stay with it, I love doing those type of movemnts as they are so simple to strip clean and reassemble, (trust me they really are) I started off on Timex movements these are solid plate movements ie you have the bottom plate then all your wheels and mainspring barrel and hairspring that you have to line up all at the same time with the top plate!!!!!
Then you had to re pin the hairspring to the top plate and adjust the screws that hold the hairspring staff in place, it was a learning curve and when i tried my first " normal " movement I found it a breeze.
Enjoy totally stripping these little movements and even if you break them keep them as you will have a load of spares for future use.
As for your question, you could do as you say but in the end you are defeating the object of cleaning it properly and selling yourself short on experience and learning. As i said stick with it, take them apart fully and most of all enjoy, and know when to step away from the bench and have a break, before you actually do break something ( as I have before in the past)
Thanks!
You're right about walking away when repeated attempts fail. I find that difficult as in a previous existence I was responsible for "live" systems in the newspaper industry and there was no walking away (unless you do it irrevocably, which I did.)
It's handling the balance assembly that's most on my mind at the moment as I have a few movements on salable watches which probably only need the balance assembly cleaned to revive them - at least as a rough and ready fix. They aren't worth much. I actually have about a hundred (possibly more) WW1 watches and movements so trashing a few isn't a big deal - and as you say, spares. These are part of the huge stock of unsold "rubbish" that an old mate of mine has accumulated over 30 years or so; I've bought stuff from him for my own satisfaction over the years and thought I'd have a crack at trying to monetise them (which I have in many cases so far). I really need to identify them all and group them by movement. A few of them (Borgels, Hunters etc) are quite nice and very salable.
Having looked at videos on hairspring and balance handling techniques it looks so straightforward... I've got a lot of PW movements too. Maybe I should have a go at one of them on the basis of big is beautiful...
Roy
In agreement with transporter on this one. if you're dealing with watches over a century old then more often than not you're going to need to dismantle to get a proper clean not to mention effective oiling.
However I do empathise with the balance handling difficulties. Practice, technique and a degree of confidence are needed. I've only been doing this hobby a relatively small amount of time and, like you, have had a number of frustrations. On the particular subject of balances below are things simply from my experience; everyone's going to have their preferences!
A really good forum thread recently was http://www.watchrepairtalk.com/topic/6497-removing-balance/ and worth reading if you haven't done so; this discusses two methods for lifting/replacing the balance. In summary one method is to hold the balance wheel and cock together; the other is just to deal with the balance cock and 'dangle' the balance wheel.
I actually use both methods! The first for removal; the second for replacement. Let me try and explain! There's a great likelihood that if the watches you're dealing with haven't been serviced or used in decades that the balance wheel is stuck to some degree. Just trying to remove things via the balance cock will probably mean lift-lift-lift until suddenly the balance wheel pops out ... or damage to the hairspring has been done. I therefore instead gently prise the balance cock up so it is definitely clear of the mainplate and effectively just gently resting there. I then take a fine screwdriver and gently lever the balance wheel up to ensure it is disingaged from the lower jewel. I then lift the balance wheel and cock out of the movement together. I have lots of professional grade tweezers but by far the best for me from trying various ones has been a cheapo pair of bronze 'size 3' tweezers!
For cleaning then I see if I can get away with not dismantling the whole balance assembly; don't fix it if it ain't broke! You'll want to inspect the pivots and assuming they're okay of course but then it's onto cleaning. For this I have a shallow glass dish that I put some isopropyl alcohol in and with a deft movement (practice this!) flip the complete balance assembly over so the balance wheel is resting on the cock. Now place in the dish. You can inspect under a loupe and if some dirt is visible another good technique is to use a simple handheld watch dust blower to agitate the alcohol to dislodge the dirt. Once happy things looks good and clean you then remove the balance assembly and rest on kitchen towel to take off excess fluid and use the dust blower to evaporate the rest. You should now have a good clean balance assembly.
After assembling the rest of the gear train to check for smooth running the balance goes in last. I use the second technique mentioned above to this by firmly holding just the balance cock and letting the balance dangle from the spring; this makes it easier to align impulse jewel. You then rest the balance cock on the mainplate and gently nudge it into its correct position. Check for free movement all the time whilst gently screwing it back into place.
Sounds easy when writing it ... but I empathise with the frustrations that can sometimes exist. Good luck!
Thank you so much for taking the time and trouble to offer this lucid description. Very interesting indeed. I wouldn't have guessed that allowing the balance to be suspended from the spring would be a safe procedure. That said, I noticed, last time when I wrecked it, that the spring remained in reasonable shape for several spillages before the elastic limit was reached. That's some very interesting metallurgy.
I have looked at the link previously mentioned some time ago. I'll revisit it shortly. I have a "free week" as ebay suspended my listing "privileges" for a week due to "Mis-categorisation". In fact their classification structure is plain ambiguous - in fact Wrong. In a previous existence I  managed the output end of the world's biggest classified ad database for a number of years. Meanwhile they allow complete misrepresentation, indeed fraudulent, of non-military "military" timepieces.
This is a terrific forum, with more intelligent, civilised content than anywhere else I've come across.
Roy
No problem! Didn't want you giving up when it sounds like you're almost there. I've only learnt my techniques through various trials-and-errors ... and of course the good advice on this forum.
Bad luck on the ebay saga. Although I don't repair clocks it's always worth looking at the Clock Corner forum of this site and read some of @oldhippy 's wittily acerbic comments about the misrepresented, um, rubbish he's spotted on ebay! Ebay carriage clock anyone ... ?! :)
Ha ha. @oldhippy... Resonates.
I'm plugging away - and extremely fortunate to have a vast amount of material to play with. Or, unfortunate, depending on how I'm feeling.
I actually have a mid 18th C recased Fusee clock with amazing pillars up on eBay now. I'm sure there's a general tendency for people to wait out the offer until the price is dropped. Not going to happen with that one.
Roy
Edited by skridlov
tyop
OK, I just finished destroying - I mean servicing - this Borgel movement. At first I thought that all was fine - balance free (more luck than judgement) and initially fired up quite healthily. I have lightly re-lubricated everywhere that I think needs lubrication (correct grease on the keyless work) However I noticed that there was an alignment problem with the s/h which was binding a bit and arresting the movement - something I've encountered many times. However suddenly the balance almost seemed to have seized - at least if rotated clockwise with a small brush it sprang back. Rotating a/c there seemed to be no tension and after a half turn or so it was halted completely. Not a clue... Here are some bad macro shots which may add something to the description. Any clues?
Roy
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
