Zenith 120 train wheels
Zenith 120
Hi,
I have just serviced a Zenith 120, with centre second hand. The problem is, when all the train wheels are in place and all other parts, barrel, keyless and motion works. The watch will wind and run, but when the crown is pulled to change the time, the train wheels lock up totally. Is this something to do with the Hack feature, or have I assembled it wrong, perhaps two pinions are opposing each other..
I have been servicing for 4 yrs and have not come across this before. The third wheel has the double pinion.
If anyone has a service schedule for the 120, or has a solution, I would greatly appreciate the help.
Keith
yes it does and holds tight. If I take the pressure off slightly with an oiler it allows you to rotate the hand wheels, but in only one direction.
There is something in opposition somewhere.
I cannot be the only one to encounter this problem, surely. :(
Edited by Legarm
Sorted it. The intermediate drive wheel for the minute cog is meant to be a friction fit enabling it to rotate. Some one had crimped it on so hard, it wouldn't turn. Stripped it an reamed it out slightly. Now working a treat.
Never worked on a Zentith movement. But sounds like you found the problem. Is it like on some Omega movement that has a cannon pinion on the third wheel?
I have worked on a few Zeniths, but not one with this type.
    • It started well. Got the clip off, cleaned in B-dip, bit of grease, then ping 😫. Lost the clip trying to refit it.    I'll get a replacement from eBay.
    • I used Google Lens on the pic and it suggested "motorcyle belt punch". And googling pics of that does show very similar tools. The end on mine is sharp, and does look suitable for punching holes in leather. I've no idea what belts on motorcyles would need piercing? The hole is about 1/4", so I cannot see a use in watchmaking. So, why have we both found one in a collection of watchmaking tools?
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
