Omega dial
antonyh
Well i could`nt resist it another Omega that needs to be done up, i won`t go into it all.
The picures are not the best, but anyway dial as it arrived,
dial after i cleaned it up just to see what it looked like, with another set of tempary hands, awfull i know.
i had polished the case up, to give it a bit of a shine, i was going to get someone to restore the dial, but prices have sky rocketed
the last few years.
so in a drunked state last night i thought i`d have a go.
Edited by antonyh
pictures wrong order
Hey, that's not bad, pictures a little unclear and I'm not certain what that dial was suppossed to look like, but I'd say I've deffinately seen worse dial jobs. what were your methods/paints? Did you remove the batons and logo or cover them somehow?
Well firsty, don`t do it after you`ve been drinking.
The hardest thing i had to get over was finding a spray paint with a fine spray of paint, i tried loads before i found one.
I just kept cleaning the dial, with thinners then i used a a brush to finish it.
i did not remove the batons, i just gave it a couple of passes with the can.
after an hour before the paint had fully hardened i just simply removed the paint from the batons.
Its not purfect but it makes it a bit more wareable than before, and its i know its supposed to have a black dial with delphine hands,,,,,,,,,,, one day..
Well It seems like you could always go back and re do it if you wanted to, the dial as it was looked pretty aweful in my opinion, though i wouldn't be surprised if someone disagreed with me I think most of us would agree that it had gone well past a 'patina'.
Edited by Ishima
Well i`ve done what i set out to do, i`ve changed the hands to something a bit more inkeeping ,i`ve filled in the end of the battons
with luminious paint as it should be , and i`m going to where it, ive since changed the seconds hand for a chrome one to match.
In the old days i would have had it restored, it its not worth the £200 + V Soni wanted last time i asked the to do a dial for me.
Dial looks a bit stark, probably the lack of minute markers doesn't help.
I would experiment and try to have a cross hair to break up the dial. Either use a sharpie, or even scribe the croshairs into the dial back to the metal with a sharp blade.
My 2cents.
Anilv
    • Back home...printing now.  Will report results
