Hi all,
In regards to cleaning the reverser wheel of an ETA 2824-2, does the wheel, after cleaning, need to be dipped into Fixodrop?
My understanding is that Fixodrop prevents oil spread, but I thought synthetic oils like Moebius 9010 didn't spread and could be used without Fixodrop?
Appreciate your thoughts.
Also, I am also not sure what oil to use D5 or 9010?
Thanks in advance.
John
After cleaning, the reversers should be treated with Lubeta V105. Immerse for a few moments, remove and blow with air to dry. It will leave a cloudy finish - this is normal.
Thanks, sstakoff, much appreciated. Someone was telling me that you can actually make your own Epilame using Moebius and some other ingredients - ever heard of this?
Fixodrop is stearic acid and shellac dissolved in isopropyl alcohol.
It's used for parts like pallet jewels. When you don't want the oil to spread around .
On reverse wheels for 2824-2 you could use Lubeta V105 or a very small amount of 9010 in Naptha . And then let i dry.
The 9010 recipe is the best i think.  I have tried both.
No info on the home brew epilame :) To be clear, the V105 is not an epilame - it's a lubricant of some sort. As far as epilame/FixoDrop is concerned, I found an open, almost full, 100ml bottle on eBay a while back. I paid $50 for it. It should last me a lifetime :) Keep your eyes open.
What kind of ratio between the Naptha (in Australia I think it's called lighter fluid) and 9010?
Thank you
Thank you
Think it is 100 to 3 . 3 parts oil a 100 parts of naptha.
