Hi, I am looking for advice about Seiko 6119 6400, to cut a long story short I am trying to replace the winding stem and crown and have hit a problem. When I put the stem into the watch it turns the inner bezel/dial but won't stay in. I have noticed the little button that you press to release the stem is stuck down,,, I think this is the problem? I have dropped a little watch oil down the hole hoping it would pop out. Has anyone any advice? I don't really wish to dismantle the watch as it is running sweetly and I am very inexperienced with watches. Many thanks in advance. Johnnie
Hi Johnnie ,
Hopefully you didn't inadvertently knock the yoke off of the groove on the clutch wheel . If the little button is stuck down , that means that the setting lever is not seated properly and not allowing the small nub on the setting lever to engage the grove on the setm.
This happens sometimes when replacing the stem .  First thing is to use the stem and crown or a small screwdriver in the stem hole to gently wiggle the parts into alignment . Doing this will work more often then not .
If this doesn't do the trick you have to remove the dial to access the setting / winding mechinism to align the parts ,...usually the yoke back into the clutch groove as I previously mentioned . Your watch is a bit more complacated because of the gear that turns the inner rotating bezel .
Attached is the PDF tech sheet for the Seiko 6106 , which is the base movement for the 6119 . You can see the parts I'm talking about ....Good Luck....
6106A.pdf
Edited by ricardopalamino
Hi Ricardo, Thank you very much for the advice and the diagrams, I am sure I will be able to sort it out now. Thanking you once again. Regards Johnnie
Hi Vinn, thank you for the advice, I will remember it. I know very little about the mechanics of watches and fully expected to make many mistakes and expect to make many more. But, every time I mess up I learn something new. This is a fantastic forum with many knowledgeable people on it and I am so pleased to have found it. Thanks again, Johnnie
Johnnie; Le Carl wrote a  book on "watch repairing' - old, basic  but very good. ( one of many good picture books).  vin
Quote
Hi Vin, advice taken, have just ordered "practical watch repairing" by Donald de Carle! I think that's the book you mean, I have taken the dial off the watch as a jiggle didn't sort the problem, I had pushed the button thing out, all back in now but winding stem still pulls out,, not as easy as it did do. It's like it's now catching but not catching enough if that makes sense? Johnnie
Is the finger of the setting lever spring broken off ?
It keeps the pressure on the setting lever that holds if firmly in place and provides the clicks for positive setting positions...[ 1st position , 2nd position for setting . It is a common problem tor these delicate fingers to get broken off when refitting . They are necessary for proper setting operation.
59062061f38f6_ScreenShot2017-04-30at7_26_45AM.thumb.png.041f3814ac98ff27e3517407c573e005.png
5906207520acb_ScreenShot2017-04-30at7_27_37AM.png.59bd5bd2d529f5f2612d485697994e2a.png
Hi Ricardo, I have just checked,, everything is as it should be, nothing broken. But in checking I realised I had positioned it wrong! Have just positioned things as they should have been and now the winding stem is fitted and has clicked into position perfectly, thank you for the "clue" and the diagram. Johnnie
Indeed so Ricardo, I can't tell you how pleased I am. I know to most people on this forum it's not very much, but to me it's great, can't wait for tomorrow so I can finish it. I have to trim the stem next and fit the strap then it will look good. Bought some lock and seal so crown doesn't undo. Johnnie
Use patience when you trim the stem . You have the added gear and spring ,[I think ] , so don't cut it too short . Better a bit long and sneak up to the right length with a fine jewelers file .
Yes, I intend to sneak up on it bit by bit until it's exactly right! Normally I am not used to such tiny tolerances but I am enjoying it. Johnnie
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
