Posting about my Sicura D500 Jump watch has got me looking at this watch, which was my 18th Birthday present in 1980.
It runs, it winds up. However, it doesn't "stop" winding, and it runs down pretty quickly. I decided to email Rotary, who identified the model, but apologised that they were no longer able to repair it.
So the question is, does anyone know of a reputable UK watch repairer who'd be able to a) assess the watch and its problems, and B) quote on a repair?
Many thanks
From your description it sounds like a simple case of a slipping mainspring. You don't need a Rotary specialist for this and it's a pretty simple analysis and fix situation. If a mainspring replacement isn't something you can attempt yourself (and I say this because any of the regular contributors on this forum could easily do this but I note you're a new member so assume you might want to leave this to someone else) then doing a search for an established watch repairer local-to-you is probably the best idea.
And if the watch repairer is going to do this repair and this watch is something you want to use and keep long term - which it sounds like it is as a special 18th birthday gift - then you should have it serviced too i.e. a general cleaning and oiling.
  • Similar Content
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
