Stuck on a watch movement AS
Danh
Hi Guys
i am struggling to find the reference for a watch movement - I need to try and source a stem for it so I can give the watch to my wife.
i think it's 1920 - 1930's, but that's a guess because the movement has a Ebauche Trust logo on it as well as the AS logo, it measures 10.5 ligne (just shy of 24mm)
i have looked for ages  on ranfft as well as Google. It has 416.9 on it as well, but I am beginning to believe this does not relate to the caliber
its a very pretty watch with a silver case, with a gold telephone style dial
thanks
dan
4 hours ago, clockboy said:
I am 100% sure as the drawing is not that clear but looking at my "bestfit" book it could be caliber 922. There is no caliber 416.9.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&AS_922&
Thank you
novice question follows:
If they had a movement and moved the parts around, (move the balance from 6pm to 3pm against the crown position) - would this be the same calibre?
the answer to this question could make identifying movements a lot harder
thank you all for your time.
dan
Ok, I give up, quiz over, you can tell us now!
I understand why clockboy went for the 922, but this appears to be a cylinder movement.
Ernst Westphal has a great selection of vintage catalogues, including one that shows pages of 10.5'" rocker bar cylinder movements all together, but I can't spot this one anywhere.
AS movements in this category are 175, 467, 740, 760, 937, 960, 1086
My advice would be to look at the drawings for AS on windingstems.com and pick the one that appears to be the closest fit to the other parts you have
You may be able to find some older movement catalogues, but yours definitely isn't in any of the ones I know of on-line
1 hour ago, rogart63 said:
Have you search here? The 437 looks like it could be close?
https://watch-wiki.org/index.php?title=Kategorie:Bildgalerie_Uhrwerke_Adolph_Schild_S.A.
Yes I agree thank you, it certainly does appear to be close
it makes me wonder that if the numbers jump between calibres if there are models in between that are not listed but closely related
appreciate your help my friend
Think there could very well be a model with that number. AS 416.9 but it's not easy to find them on google? Even the prima primarosa is close?
But from there to find a stem that works? Maybe it would be easier to measure the clutch wheel and the movement plate and from there try to find a stem that could fit? If you go to windingstem.com you can type in the measurements and see if there is a stem available?
8 hours ago, Danh said:
Interesting - windingstems.com lists an AS415 as being a calibre
Strange that "Bestfit" does not have the 416. Also cousins also do not recognise the 416. Personally if it was me I would just purchase a stem for the caliber 922 from Cousins which is approx. £5.
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
