Seiko 6119 6400
Hi everyone, I am pretty new to watch repair and need to ask the forum a question (probably hundreds of questions really) anyway, I have a Seiko 6119 6400 that is running when shaken but is missing it's crown and winding stem. I was wondering if anyone can tell me where I may obtain these parts? Many thanks in advance. Johnnie
Take a look here. http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK+CS%236119-6400&submit=Search
There you can see which parts you need. Finding them on Ebay and other places.
You will need a special stem and gear for the inner bezel to work.
That is not easy to find. And will cost some money.
Edited by rogart63
The gear for the inner bezel could still be in there? Then you will only need a new stem? Those i have seen on Ebay . Crown is the same as the Pogue. There is AM crowns that look almost like the original. Nice watch that is well worth restoring. Have done a few .
Hi again Rogart63, I have managed to obtain a new crown and winding stem (£50.00) not cheap but the watch looks awful without it. I am very new to watch repairing, the spring is still there so hopefully it just needs the crown and winding stem. Could you tell me if the stem simply pushes in, or is there more to fitting it than that? Any advice would be most welcome.
Ooops . That is in a way good? That means that the small gear the turns the bezel is probably there also. But that does also mean that the rest off the stem is still in the movement. And the movement needs to come out? Maybe just maybe you can take the stem out if you can grip it with something? At the same time as you press the release button on the movement.
You will need to shorten the stem when you get it. Taking in that the date mechanism need to work when you press the crown in. Little tricky.
But first get the old stem out. And we take it from there.
First try to take the spring out?
But well worth saving that watch
Edited by rogart63
Thank you Very much Rogart63, I won't get the new stem until the 28th, looking at the watch I think you are right, I think I can see the end of the stem. I will attempt to remove it tomorrow in daylight as I struggle with artificial light. Many many thanks for your time and advice it is most welcome. Regards Johnnie
Hi Johnnie,
You say it runs when shaken? These watching cannot be hand wound (hence winding-stem is actually a misnomer), you need to shake it for about a minute to get a decent amount or mainspring power on it.
Having said that, if the crown has been missing for some time it would be best to service the movement as a lot of dirt can get in thru the hole.
Anilv
Hi Anilv, I think you are probably right about servicing the movement, the problem is I don't think I have the skill and knowhow yet! I have a Seiko 6319 7010 that I have disassembled and oiled and hopefully on reassembly it will work,,,,,,,, maybe!  Johnnie
Think so to. But start with the stem and get that working? Then you have at least all the parts to make it complete? As you say. Service can be done later. When you have accomplised the skills to make the service. 6119 movement isn't that much different then the 6319 .
Hi, hopefully the stem and crown will arrive in the next few days? I am trying to find a diagram of the crown stem gear and spring assembly, the watch arrived without the crown etc so I didn't disassemble it, so have no idea of the correct way it should be assembled. The last thing I want to do is ruin the watch!
Can post a picture of a similar crown in a few days. Have a Seiko Pouge on the way.
But you can find a lot of pictures of the similar  crown and stem with gear and spring on the net.
Stem need to be shorter then on the picture. But the exact length you need to find out when the parts arrive.
Edited by rogart63
Well here I sit contemplating my next move! Can't seem to get the new stem to engage properly. The new stem is correct as I have compared and measured it twice. I have tried pressing stem release button but that doesn't help. I don't want to force it so I have walked away for a nice cup of Yorkshire tea, any advice gratefully received.
I think.... I know why stem won't engage and stay in... The little stem release button has stayed down(I hope this is making sense) any ideas??? Or will I have to take the watch to pieces??? I don't really want to as the watch is running sweetly and I am not very confident about doing that. I have dropped a little watch oil down the hole hoping it will release and pop back up. Any advice please.
  • 3 years later...
NOS Original Stem for Seiko 6119-6023 6119-6050 6119-6053 6119-6400 6119-7160 63
Seller :
seikosis (7392 ) This advert is on eBay at present so good luck.
On 10/12/2020 at 5:35 PM, mtreed2009 said:
Hello Johninie. Could you direct me to the place where you finally found the Stem and Crown for the 6119-6400?
Thanks
Mtreed2009
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
