Had an interview today and wore this for luck. I had this overhauled over the Summer and it is a handsome piece indeed. Month, day, weekday are set..the moon phase...maybe I can count the clicks? 2470538a8542be71f0cfa167fbbc48f3.jpg
Sent from my SM-G920V using Tapatalk
  • Like 7
Gorgeous! Rare to see one in such good condition. Did you have the dial repainted?
Thanks StuartBaker104. The dial is original, only the crystal and day hand replaced. I love the copper numbers against the tan dial.
  • 4 weeks later...
Wow!  That's really special.
I've been looking for something like that in a modern-production piece and can't seem to find it.  Of course, Patek makes several that are similar but, I won't be purchasing any of them -not in this lifetime, anyhow.
Why in the world won't a modern watch-maker produce something like this?   Maybe I'm not looking in the right places.  Does anyone know of something modern and similar?
Ray
Ray
Here's a couple and then for something a little more affordable (Ingersoll)1359cdb45553f828b20c885d03d7e57e.jpg0eb3493e5bcfe0205371cccfbbb954a9.jpg5279d9e3a6d8e504befef25e68c820e1.jpg
Sent from my SM-T585 using Tapatalk
Thanks so much for the ideas and tips!
One other question, if I may...  That beautiful Pierce:  About when was that made?
(Just trying to figure out how long it takes history to re-invent itself).
Ray
Unless the OP can offer something more concrete, it would date from about 1950 and will feature the Pierce 103CLD movement.
Part of the attraction of vintage watches like this for me is the curved dial and curved acrylic crystal. There are few modern watches made like that, although the Longines Heritage range and the Seagull 1963 replica come to mind.
Ray
Hi Ray, thanks for the nice words! I haven't got into checking out the S/N on this one. I would imagine my grandfather may have had one watch between his WWII ordinance watch (Waltham 9j) and the pierce. I would guess late 50's to mid 60's. Others feel free to chime in.
Ray
Here's another. No its not the Rolex circa 1931 perpetual automatic design. See the date91215dae6854333b8ddb5ab1a0077721.jpg
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
