Hi
Working on a Seiko 7s26c ...I need
A - (1) Date dial Guard screw Part # 0012 354
B - (1) Day Date corrector Wheel Part # 0737 300
Does anyone know the best place to purchase these parts in the USA.
I have searched part numbers on a few sites Esslinger and Ottofrie but no dice.
Regards
Anthony
Mate jump on ebay and search for "thewatchcollector" Ramon is a source of many seiko parts mostly used, he usually sells batches of old movements for very little, I grant you they are dirty and some will never run again but they are a cheap way of getting alot of parts, and he's based in US but the items come from the phillipines, but he is very trusted throughout the seiko community, myself included.
5 hours ago, adiorio110 said:
Hi
Regards
Anthony
Think i could have those? Send me a PM . I  can take a look?
Didn't read that your are in USA . That will complicate things a bit :)
Edited by rogart63
Rogart
I found the screw and  I located the part I needed part #  0737 183 ..The other number was for the B version. Its only 4 bucks it would be more to ship it from Sweden . But thanks for the offer .
Anthony
Anthony. I should have day date corrector. I have b and c parts and I would just have to check to make sure it's a C part if applicable. Do you still need?
Yes I can still use the c version.. Let me know
Thanks
Anthony
Anthony,
OK, yes I have the "C" version of the plastic corrector wheel.  I am in NJ and I think you are in NY?  You may have it for FREE.  I think if I tape it between two business cards and put it in a standard envelope it should be OK with just a forever stamp.  If you want me to put it in a bubble envelope just go to USPS.com and send me a prepaid first class postage from 07930 to [email protected]
ALTERNATIVELY you can have the whole movement for $25 plus postage.  This was a brand new movement.  It is missing three parts, the day wheel, the hour wheel, and the clip for the day wheel, otherwise perfect.  PM or email me what you want to do.
9 hours ago, dman2112 said:
Anthony,
dman2112
I'll pm you
Thank you
Regards
Anthony
dman2112
I have a few Elgin Pocket watch donors if you ever need something and I have it. I would be happy to return the favor.
Regards
Anthony
16 hours ago, dman2112 said:
Appreciate it. If you come across a main plate or a balance for a 8/0 539 let me know
I have a few size 16 and 18's no 8/0's sorry
1 hour ago, dman2112 said:
Anthony. On its way. You should get it tomorrow or Sat
You the Man... Thanks .. I ripped down and rebuilt the watch 3 times.. Of course I could not completely check my work without that part. I am excited to see how I did. Hardest part was getting the roller jewel in place.. But I am getting better(quicker) at it ... Have you been doing this long?
Any suggestions as to what I should try next?
I'm thinking about perhaps buying a broken day date watch and trying to trouble shoot and repair it.
Regards
Anthony
Thanks again... dman2112.. I already received the part and installed it ... Everything works fine ...I already ripped down and rebuilt this watch 3 times ...Now I have to tear it down, clean and oil properly  before rebuilding it again. That should go pretty fast.
Already looking for the next level build.
Regards
Anthony
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
