Hello from Essex.
Hello there.
I would like to say hello to all members!
Ive been collecting watches for over 10 years now, it all started when my dad gave me his favre leuba quartz from 1981 which by the way is still ticking away. Consequently I now have a passion for the Favre Leuba brand (beautiful watches in general too)  I have a good collection building up now. My latest acquisition is a 2017 Rolex Datejust II with the smooth bezel and blue dial on a oyster bracelet. I will love to post some pics up in the other forum later.
Ps I'm off to Baselworld next week can't wait to see the new FL pieces that they are bringing out : )
anyway enough rambling  bye for now
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
