Hello all. I'm learning the basics on an at1867 manual movement and the incabloc lyre spring on the bottom side of the balance wheel broke as I was removing it. I would honestly say this must be a material fault or brittleness due to age hardening as only the slightest deflection was applied when the leg on the lyre spring failed.
Just do curiosity I have pressed out the block (having first removed the jewels) and replaced for practice.
My question is, can I still procure the incabloc and lyre spring for the st1868 movement, or do I need to be thinking about looking on eBay for a scrapper of the same ilk? Bearing in mind I paid £4 for the watch for purpose of practicing on, I'm not looking to pay silly money for for a nos part. I'd be happy to buy one from anyone here who is prepared to sell one to me.
I look forward to hearing from you.
Kind regards, deggsy
The incabloc springs come in different sizes . You can buy them at cousinsuk.  Just has to figure out which one you need.
But can't find anything about ST1867 ? Are you sure that you have the right number for your movement?
A bit confused what this movement is. I have a incabloc catalogue but no ST1686 or 1786.
However in this range,  the lower spring is 170.03 & upper spring 173.03
Hi. Sorry it's st 1686.
Thanks clockboy. Where did you find this information please? If I ask you now, it may be helpful in the future. Regards deggsy
I own a incabloc catalogue . However the catalogue is available on the Cousins web site. You can cross reference by measuring the cap jewel to get the correct spring. Cousins sell them in packs of 5 or you can purchase a selection box for approx. £50
Thanks clockboy. I just visited the incabloc web site which is very informative. I can see why you were confused, as as am I, AS1686 isn't listed under the AS movement manufacturer. Is As1686 shown in your catalogue you own?
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
