Hello from Brighton, UK
jmw
Hi, JMW.
This is the best forum to join if you have an interest in watches.  It's not just a place for show-and-tell (although we do love a bit of show-and-tell).  If you have questions, no matter how trivial or no matter how involved, you will find the friendliest and most helpful people right here to help you out.   Welcome aboard!
Edited by sperki77
accidentally entered before I was ready.
    • Very best wishes to you and your family, as a carer myself I know how difficult things can be.
    • This digital watch works but the buttons can't seem to be working does anyone know what could be the cause a have know idea?
    • Sorry I'm back again the reason why had   push the jewel out was someone had fitted a wrong one a couldnt get any end  and side shake with the old one ...I'm replacing it.
    • Tah-dah. A mini blow torch to harden it, then quench it and just a lighter held under a brass mainspring barrel that the part sits in to temper, Its important to wipe off any grease from fingerprints with ipa, you might be able to see i missed a bit at the top of the arm. Its a very satisfying process. I now just need to deal with the more difficult repairs, anybody any good at replacing rubbed in jewels ? 🙂
    • No I haven't tried that, I'm just thinking of the most complicated solutions 🤣   Another great idea 👍 All I need to do is hold that little bugger steady while I try and screw it in, without starting to shake, it gets the better of me sometimes but is getting less the more I do 😀  I need to order some bits from Cousins so I decoded to put this to one side until I get a balance screw holder, it may come in useful later on as well. I'm assuming it closes down enough as I don't know the diameter of a balance screw compared to the stud screw, I haven't worked on a movement with balance screws! I'll be getting the cheap one 😆
