Hi
I've got a nice Allaine watch with a Felsa 4007n movement. The watch runs well in 4 positions, amplitude a bit low so I'm checking the train and mainspring, but beat error is 0.2 or less and time consistent  within a couple secs -/+. However to achieve this the regulator is completely over on the + side - hopefully you can see on the photos. What would cause this, incorrect replacement haispring perhaps? As I said it does run well and consistently, but I like to do as good a job as I can and this doesn't look right. Thanks
Stephen
I'm a relative newbee but it seems to me that the main point is error and power reserve.  If a watch is maintaining small positional errors and has a good power reserve, then I don't worry about amplitude.  If it runs good, it runs good!
I would think it a bit strange if the regulator is meant to be in that position. It makes a very large gap between the stud and regulator pins, and also would mean the timing is only adjustable to make the watch run slower.
Have you tested to move the beat error arm all the way to the other side?
Sometimes i could find a good beaterror on two positions?
Either that or the hairspring is in the wrong position?
Yes, I tried that, it just loses time and then goes completely haywire. What's puzzling is the fact that it is working perfectly when the regulator is adjusted to this extreme position. That's why I wondered if it could have had the hairspring replaced, but I don't know if a watch would work that well if that was the case.
From the second photo, it looks as if the hairspring's out of shape. The terminal curve looks all wrong, and the gaps between the coils look are uneven.  If so, I'd be more than happy if the watch is running well in any position... :)
I re-built a 4007N in a MuDu a little while ago, one of my first attempts. Looking back at photos of the completed movement, the regulator was in pretty much the same place as yours but the regulator pins were only about halfway along the terminal curve. I think maybe your hairspring is wrong/damaged, but I'm just a beginner so let's wait for some second opinions..!
Thanks for all the suggestions. I've now put a new mainspring in and the amplitude is much improved, all readings are great. There is something not quite right with it, but as it's working so well I'm just going to leave it alone for now.
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
