Replacement parts EB 8400
Johan
Hi,
I have a problem I'm hoping you can help me with.
I have an EB 8400-74 movement and have managed to loose the balance jewel. It's an Novodiac shock protection but I have problem finding the correct dimensions to order.
Does anyone have any idea where to find thsi information?
18 hours ago, Johan said:
Hi,
Welcome Johan,
If this is the same Novodiac system as the Bettlach 8800, then I have spare balance jewel and setting. I am not sure if its the same, but cousins does note this as the same part for the 8400-74. I can't find any images for the movement, so can you post a pic?
J
22 hours ago, noirrac1j said:
Got it Johan. I'll be home in a couple of hours and will check through my parts. I know for sure I have EB 8800, and I can send you that for you to try, but I also have some other Bettlach movements I can check. More to come.
J
Awesome! But I must warn you, I live in Sweden so I don't know how much the postage will be...
I wonder if an inca-jewel might fit?
I might have a few of those myself. I guess it won't hurt to try...
@Johan I found three Bettlach movements:
an 8461 complete movement and I can send you the balance jewel setting and spring or any component thereof,
an 8800 complete setting, jewel and springDSCN5055.thumb.jpg.62b09825794cd5ca27b8630d1554a7dc.jpg
and another type of 8800 balance setting with KIF spring but I can't find the jewel (lots of smal envelopes to look through).
Will any of these work?
J
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
