I am having no luck finding screws 54000 (10.513.01) for ETA 978.002 quartz movement for fixing the circuit board. All usual sources have no stock and I have none in my own stock of over 300 screws!!  The only sources I have seen is for full movements at £10-15.  I do FOC repair work for a local charity so cannot justify this cost for the 2 screws that I need for repairing a low value Rotary Ladies watch.
If any one can help me out it would be most appreciated and I can pay reasonable costs.  I attach a drawing of the screws required (2 off needed), the critical dimensions are the thread/shank diameter and the length under the head.  The threaded length must be a 1.10 mm minimum (fully threaded is ok).  All dimensions are in mm.
ETA 54000 Screw-978002.pdfFetching info...
Have a few old ETA movement that looks like yours . ETA 255.461 and a few others? Maybe there is one or two that could work? Will take a look?
Not the easiest to find? Found some but with my caliper they measure 0.65 . Could the be within the error of the caliber or are they to large?
Also found one that was 0.53.
Maybe they are 0,5 and 0,6 mm and my caliber measures a little wrong? Will look with my micrometer tomorrow?
Does look like i only have the 0,65 mm screws? Sorry can't help you there?
Found a smaller one to but that seams to be 0,55 when i measure with the micrometer.
Hope someone else has the right size ones?
Thanks for all your efforts.  Clockboy I have recently purchased 2 different packs of mixed screws (I found these to have a very limited selection and many of little use!) and 1 pack of battery clamp screws recently and none have revealed a suitable screw (0/500), mainly too short !!
I have measured a 0.6mm tap and this indicates 0.59mm on my gauge so I guess the screws are tapped to the standard 0.6mm.  On this basis maybe rogarts 0.55mm diam may be a possible rather than the 0.65mm which I don't think will go down the tube.
Rogart - re the 0.55mm diam, is the length ok, slightly longer would be ok and the head dia is not too important so long as it is near. If so would you be able to mail it to me?  Being cheeky, I really need 2 of them if you have.
Edited by canthus
What a great group of forum members who are only too willing to help a fellow member.
Rogart kindly sent me some screws but unfortunately none of them directly fit but I am going to try and modify 2  of them.
This may not work so still on the lookout if anyone can help.
Managed to reduce the diam over the full length and re-tap the end 0.6mm, the lengths were ok as they were. The screws now fit fine and the watch has been returned to the shop.  :woohoo-jumping-smiley-emoticon:
Might add that the 1st one took ages as I don't have lathe and had to do by hand filing and finishing, and the use a tapping block to re-instate the thread. In the process I developed a couple of holding jigs from the veritable CD case, so the 2nd screw was a doddle!! :)
Thanks again rogart for the long screws.
Edited by canthus
    • What's the movements so we know what size cases you're looking for and what are the setting requirements.
    • As I am getting close, I would like to know the total thickness of the bezel (top to bottom).  I am working on two solutions--one is thinner than the other.  The crystal sits pretty proud relative to the bezel, and seems consistent with the pictures I have seen.  But, actual measurements would be nice.
    • A little bit of superglue and you'll be good to go Although maybe if you had a laser welder you can weld the spring back together. Typically I've only seen it on blued steel Springs and on one occasion a modern spring? The modern watch was a Rolex watch that came and that was literally filled with rust including the barrel was filled with rust in the spring was in a whole bunch of little pieces. I have to wonder if that was an aftermarket mainspring . Then I'm attaching a PDF the Elgin watch company as you can see instigated a study in the 30s find out why mainsprings were breaking. I do though wonder if perhaps there may be a flaw in their study? One other things I wonder about is the metallurgy of the early steel Springs versus the later generation of blued steel Springs whether the metallurgy as part of the problem but in a case they did a study and have attaching a PDF. Because of the study any time I do anything with the blued steel spring when I actually cannot get something that's not blued. Once the spring is cleaned I'm very careful to not to touch the spring with my fingers because I don't want to have a problem with the chemicals on your fingers causing rust and I very carefully get lubrication back on the spring as fast as possible just to avoid these unpleasant situations. Then yes it is interesting one minute you of functional spring and the next minute you have lots of little pieces of spring. For my own personal Elgin pocket watch I put a steel spring and in this happened I'm also guessing that when one layer breaks it sends a cascading shockwave through the spring and that's why it breaks all the way across because after all there is a lot of energy in the spring when it breaks. Oh and my theory on the metallurgy is based on things have improved and for the most part I don't think I've seen a shattered spring in quite some time.   Elgin_Mainsprings.PDF
    • Hi all A bit of an off chance one but has anyone got any links to suppliers of Conversion cases, to adapt pocket watch movements to wrist watches. I have a couple of movements and bring in the UK there is little chance of finding a replacement case so thought about converting them to wrist watches, I have seen loads of converted watches for sale so there must be a supplier somewhere, anyone know of a supplier. Thanks Paul
    • Thank you very much. I routinely harvest these strips so will be able to attempt a repair - much more interesting & potentially satisfying than acquiring a new replacement item.
