Hi all,
I'm new here – very new. And I come to you as a simple man with no watch repair skills – I just hope you can help.
I bought an extremely cheap HMT Janata watch from an indian seller on eBay. I've done a lot of reading so I know it might be fake, and I know the face might be repainted.
589655399120d_Photo_04-02-2017_10_09_17_pm.thumb.jpg.b9305c11b32ff97cc741287b5aacf3ee.jpg58965566d6dc8_Photo_04-02-2017_10_09_50_pm.thumb.jpg.db66a21d35bc9fa26f30960b7744447c.jpg
But – the stem broke back in November. I took it to a local repair place and it took them roughly two months and five visits from me to tell me they have no idea what it is and the movement is 'something probably indian'.
It took me about ten mins to find the following info – so I thought I'd like to check them with the geniuses here.
IF (a big if) it's real, it looks like it's this movement: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&HMT_0231
Which is 'basically' this: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Citizen_1802&
Which it seems would mean – I would need this replacement part? http://www.ebay.com/itm/Citizen-cal-1802-watch-movement-part-winding-stem-/361635637962
Like I said, I'm not really in a position to repair the watch myself but I'd be happy to buy the right part and hand it over to someone who could.
What do you think? Is that the part I need? If not – what should I be looking for?
Any thoughts or advice would be much appreciated – I've got a lot of respect for this community.
Cheers,
Sam
I think your investigation work looks solid. Depending on where you are based, maybe look at the Cousins website to see if they are cheaper. Stem release appears to be by pushing that small button (gently!).
Welcome to the forum. I also have some HMTs, they were the first watches for practice :)
It seems to me from the picture that the case tube is distorted which can couse winding problems, or braking the stem. One HMT of mine had the same problem. You should replace that as well, or at least remove it before inserting the new stem.
I would buy an other one for parts. It is so cheap from India lol
Hi Rodabod,
It looks like the stem broke flush with the crown. If there is some threaded portion left you could use a 'stem extender', for mechanical watches these are usually a 0.9mm thread.
Your watchguy should be able to do this but a) he may not be into mechanical watches and just wants to sell you a new watch or b- there may not be enough space for a thread extender to work. The fact that he could ID the movement speaks volumes!
You would need a new crown of course and one with a shorter tube (where the stem would screw in) would give more room for the extender. The crown tube can be teased back into position by using pliers but put something solid inside to prevent it collapsing. A new crown and case tube would improve the water-resistance as the mangled crown tube will never be water-tight.
HMTs seem to be a bastard Citizen so the stem you found on ebay should fit but I've bought a lot of stuff off the bay that don't fit!.
Here's recommended action plan (assuming you have some thread left on the original stem.. post some pics of the movement here and we'll tell you if you have enough to work with).
1. Buy crown
2. Buy a 0.9 stem extender
3. Buy a caseback opener.
4. A crown tube is optional.
Where are you in the world? Someone should be close enough to give you some tips where you can source the items. Stem extenders are available online but usually in packs of 10.
Get the following tools ready
1. Fine file
2. Side cutters
When you've got the above lined up, come back here and someone will guide you.
Anil
Thanks all – very helpful! I've ordered a new stem specifically – and if my local watch guy has trouble with that I'll just buy another hmt for the parts (very cheap as you all know).
Thanks again!
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
