Bought a nice working omega Chronostop jumbo a few months ago. Looks and have a little patina on the dial? And the case has been polished. Wrong crystal to . So i was thinking if i could  do the sunburst grinding myself with a jig or something? Doesn't have to be perfect. Just as good as i don't have to see the polished case. Do you guys have any tips for an easy jig i can use a sandpaper in ? It going t be a watch i use a lot so will get a few knocks here and there maybe. Better to look original with bad scratches the polished to a dull boring case? Pictures will come.
Here's how I do it:
Take a piece of hardwood around 3mm thick. Glue a strip of 600 or 400 grit wet and dry paper to it. Stroke the abrasive against the surface and rotate the case slightly with each stroke. This sounds a bit basic but it is possible to achieve an excellent finish doing it by eye, I hold the case in my left hand and work the abrasive with my right.. You may to go over it a few times, but the end result is good. You have to imagine each stroke going through the centre of the dial, that's the way to get the angle correct.  I`ve refinished several sunburst finished cases this way and people have always been impressed with the results.
I was surprised how easy it is. I tried setting up a jig but found this method worked OK..
Best to practice on an old case to get the technique, and be sure to mask areas you don`t want to refinish. As with all things, there's a degree of skill involved and you do need to practice first.
Paul
6 hours ago, ro63rto said:
Could this be used as a lapping machine or is the disk too small?
PARKSIDE Disc Sander
http://www.lidl.co.uk/cps/rde/www_lidl_uk/hs.xsl/productPageFinder.xml?listId=1063&articleId=41505&type=offerdatelist&productId=41505&countryCode=GB
Sent from my Honor 5c
Maybe could be worth a try? If Lidl sells it here in Sweden? Could maybe have other use for it to?
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
