Yurman Watch Grief
I took this thing in to replace the cell and polish the case and bracelet. The dial worked loose from the mechanism, I reattached it but when I re install the hands , the minute hand pops off as soon as I put the case back on. I reattempted the procedure three times and yet no success.
Has any one had experience with these?
From your photo it looks as though there's nothing for the minute hand to get purchase on. The canon pinion should be slightly above the hour wheel?
If that's the situation, the dial might be too proud of the mechanism - and the re-installation of the case back may well be causing that. Beyond that my knowledge peters out!
Just a thought from an amateur tinkerer...
Edited by WillFly
Yes, Will is correct, the photo doesn't show too well what the situation is and it looks like there is no room for the minutes hand there. It comes to mind that maybe the dial may not be fully seated in the case so the movement is staying a little behind its regular position. Also the dial feet are not fully seated. Either way the dial acts like a "hands puller". Or simply there is an obstruction somewhere in that area that prevents the movement to come forward as much as it should. But it could be that the minutes hand is loose in its seat? mmm, I'm running out of options here! In any case, patience is a great tool in those cases! Hope it ends well!
Hi,
   It does appear as if there is nothing for the minute hand to sit on. You might try to set the hands with stem. If hour hand moves then it may be as simple as pushing hour hand down a bit more. If hand doesn't move then it's possible that hour wheel isn't down far enough on canon pinion. This can happen if teeth of the hour wheel are sitting on top of other gear instead of meshing. Thing to do would be to remove dial and insure that all wheels are down far enough including canon pinion. There also may need to be a dial shim between dial and hour wheel to prevent it for riding up that may be missing. And of course the dial may be up too high as has already been suggested. Just wanted to give some other possibilities to look at.
Charles K
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
