I have some Moebius D5 I bought from Cousins last year. It's a 20ml bottle which I'm unlikely to finish in my lifetime, let alone between now and the end of April 2017 which is the shelf life expiry date of this batch.
I haven't been able to find a clear answer to just what the expiry date means for the oil in the bottle. Does it mean the oil should no longer be used from that date? Does it mean that if you use it at the end of the shelf life period the oil will do its job for another two or three years in the watch? Either way, as a tinkerer I'd be content to use it for the next couple of years. That would still leave me with more D5 than a hobbyist would ever need, so I'm planning to keep 2ml and I'm offering the rest of the bottle to other tinkerers in either 1ml or 2ml doses.
I have some new small 2ml glass bottles, an unopened syringe and a blunt mixing needle to decant the oil without contamination. You can have it for free, but I'll provide my paypal address in the package if you want to make a voluntary contribution to the P&P. If all of the oil is taken I'll post an update in this thread.
PM me with a postal address and tell me whether you would like 1ml or 2ml.
  • Like 7
44 minutes ago, vinn3 said:
i don't think oil has a shelf life.
Of course it has it. Especially natural oils like this one are subject to a faster decay.
Interesting regards oil shelf life. Synthetic has practically replaced the old type oils. I wouldn't rush to dispose of your surplus d5. I would be happy to use in 2017 and service the movement or inspect it 3 years later. As a hobby where low volume of oils is going to be used, mobius 9104 is a far better choice than d5. It's suitable for all d5 applications and is fully synthectic and is good for 5 to 7 years at least.
I sort of think regards shelf life while the oil is reducing friction, lubricating, not gumming up, it's good to go.
I suspect specific shelf life is more to do with marketing ploys than reality but it shouldn't be ignored
Sent from my SM-T585 using Tapatalk
+1. (It's also known as HP 1300).
I suspect there's a lot of snake oil (pun not intended) in the watch oil industry. Synthetic oils are not necessarily better in all respects, and natural oils have their own advantages in some cases. I wouldn't be surprised if this bottle of D5 was perfectly useable for several years. Perhaps the only fair way to test would be to leave droplets alongside some alternative oils and monitor how they deteriorate over a long time.
  • 2 months later...
Hello Mike,
You are awesome, really few people will do that in the same situation.
I'm sure you are a good person, you helped me to recover faith to humanity :Bravo:
Have a good day.
Julien.
    • I also still use my cheap first set of screwdrivers. I replaced the blades of the smallest (0.6mm) with higher quality once I had bent a few of the originals, but beyond that I have been fine. Note though that I do not work on any remotely valuable watches and most of what I deal with are in a truly terrible state, watches that have been banging around in kitchen drawers or toolboxes. So my concern for screw head slot integrity and scratches is usually not very high.  As for a loupe - you won't need anything powerful for an ST36 that is new. You don't need to do close inspection of balance pivots because they will not be worn out, and a 3x or 5x loupe is perfectly sufficient to see the oiling. I don't have any microscope or powerful magnification of any sort. I just use cheap loupes. But again this would be different if I were working with more valuable watches. And if I had equipment to burnish pivots, then I would get a microscope to check my work.
    • I've recently switched over to using a x2.5 -x3 eyeglass for disassembly and some larger part assembly. It's interesting to see how accustomed and trained your eyes become to that way of working after using a microscope for years. And pick up and work at eyelevel when possible. Personally I would stick with and learn to use regular oilers efficiently.
    • I remember playing with asbestos wire insultaion when I was a kid (remember the cool fluffy white stuff?) and I've been breathing fine dust particles in my woodworking shop for years, so I'm probably toast either way, but I don't want any of this radioactive dust anywhere near my kids.
    • Its good to understand how and why demagnetisers work. These two pieces of text explain in basic terms how ferrous metal is affected by magnetism and why they can retain some of those properties.  The cheap demagnetiser is actually a magnetiser,but is used in a way that can remove the weak magnetic properties that a steel has gained through magnetic field exposure.  As steel is drawn further away from the device, the magnetic fields around it become progressively weaker and more -irregular- . This causes the disruption of the atomic and subatomic alignments within the steel that make it magnetised. So also moving the steel  through different orientations as its pulled away could actually improve that process. I still use my first cheap set of drivers, I notice very little difference in the way of feel between them and a set of preowned Bergeon I use, blade quality is more important. Tweezers have more variables, but again they don't have to be expensive to work well. My most used tweezers are my cheapest, but then I never use any pair that I haven't modified in some way.
