Tiny spring change
One of my neighbours recently gave me his wife's watch to look at, he just said ''it's not working do you think you could do anything with it ?''.
It's a tiny Seiko ladies watch, I took out the movement and found a broken click spring,
nothing remarkable about that except it must be the smallest click spring I've ever seen !  barely visible with the naked eye , Cousins even had one !   ( £1.50 )
Watch now working  :)
Just thought I'd post it.
On ‎10‎/‎01‎/‎2017 at 6:28 AM, anilv said:
 I currently have a ladies Eterna 1441 on my desk and the **BLEEP** clickspring is giving me grief.
I actually fitted the spring with the movement in the storage tray in case it dropped ( as in photo ) then I layed the the spring in place without putting it under tension until I covered it with the click & started the screw about half a turn, this stops it flying away when you locate it properly.
Hope this helps  !     :)
  • 10 months later...
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
