Waltham PW Mainspring Disassemble
MrBeat
Happy New Year All :)
Well its a good start to the year and ive already come unstuck.
I don't usually work on American watches but i have a Waltham that requires a new mainspring and ordinarily this is a non issue but i can not see how the barrel comes apart to change it as it seems stuck in place ? Does the barrel arbour get punched out ? I can not for the life of me see how to get this out it seem intent on staying in ?
Any help with pointing out my obvious error will be most appreciated, Photos Below >
It appears theres play but the thing does not want to come apart, am i missing a secret here ?
Well the penny dropped :D
Turns out the arbour is a two piece that screws together, although this one had ceased and just needed an extra umppfff to get her to release. Apparently this is a common assembly on Walthams of 19 Jewels ( this case a Cresent Street ), a small and old picture on the interwebs from Waltham shows the assembly which is why it had me baffled for a moment.
Now the parts are cleaning before new spring is fitted, problem solved :)
  • 4 months later...
@MrBeat @oldhippy I'm in the middle of replacing am mainspring on a Waltham 12s and I'm having similar trouble.  I thought maybe the plate held the assembly together, but it's near impossible to install without the mainspring lifting the cover slightly off the barrel, unseating the pivot.  I had no trouble getting the arbor out though, this one appears to feed through the assembly, but there is no means to keep everything captured prior to installation.  Really stumped here.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
