Fast/Slow 6497-1
Folkvisor
Hi
I am having a problem slowing down my 6497-1.
I've moved the fine regulator - both ways - there's no +/- on it so I was experimenting. I am wondering if I should move the hairspring stud a little to loosen the mainspring. It goes 5 minutes fast no matter what I do. It seems to keep time quite well for the first 12 hours so I guess it can just be set every morning.
Other than that it works well.
Any ideas?
Dave
You don't want to move the stud as this affects the beat rate.
Are you only moving a micro adjuster as opposed to moving the regulator pins directly? You have to set the micro adjuster (if fitted) to the central position, then set rough adjustment by moving the regulator (index pins) directly first.
Edited by rodabod
Moving the regulator isn't always the answer to regulating the watch there's unfortunately more to it sometimes. For instance what kind of a regulation system does this watch have? Then was there a sudden change in timekeeping which might indicate something other than a regulation problem? Then if the watch keeps time for the first 12 hours if I'm interpreting what you're seeing correctly then goes fast it's probably not a regulation problem.
So I've attached some images there should be two separate types of regulation systems for these watches. The older conventional with standard regulator pins and the newer etachron system. Then the components functions are similar but moving them is different. So in one image below is a breakdown of the separate components. Both systems would have similar parts it's just the etachron makes things easier and at the same time makes things more complicated.
This is where having a timing machine/timegrapher Will make things a lot easier and avoid complications.
So the regulator itself is broken in the two pieces. 28-3 which basically is a very co**BLEEP** adjustment and 28-4 Which is the fine adjustment. With the older system that you could move either the fine or course adjustment just fine but with the etachron system it's a little more complicated.
So once we figure out whether it is a conventional regulation system or the etachron system we can go on with regulation. Then a picture of the watch preferably centered over the balance wheel would be helpful seeing where the components are seeing if there's a problem with the hairspring would be helpful.
Hi Guys
Happy New Year!
Anyway, I was moving the regulator pins the wrong way. When I asked my watchmaker friend he said, "So, you moved the regulator pins closer to the stud and it went faster and then you moved them even closer and it went even faster?! What, if anything, does that tell you?!"
He just looked disgusted when I said, "I moved it the wrong way?"
I'm glad I don't work for him.
All the best in 2017.
Dave
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
    • The problem with oil in particular 9010 is it likes to spread. This is why you're supposed to use epilam anywhere it's used to keep the oil in place. Then you want to splurge on money you could buy 941 it's actually an oil that existed before 9415. Then the problem with the grease yes it stays in place but if you have too much you lose amplitude. Then if you get really obsessed with this he would follow Omega's recommendation for escapement lubrication. One of the problems with internal documents of the watch companies is typically are never going to see Them.But a few of them out in the wild for instance at this link Below I searched for the keyword of working. In particular working instructions of the Omega watch company for which there is way more than This but this is all they have. So you want to download number 40 as were going to talk about that and also download Number 81. Plus anything else that looks interesting https://www.cousinsuk.com/document/search?SearchString=Working Then number 40 covers lubrication of the watch. Most interesting is lubrication of the lever escapement under three different conditions with Lubrifar Which you probably no longer have has been washed off without which is what you have and then a course with epilam. Notice how they go supers super minimalistic with the 9415 because if it's too heavy you lose amplitude. Then if you lose amplitude the group will be disappointed with you and the end of the world will come.
    • You would always get an answer John, you dont need to be dramatic or humerous to get one, but it was appreciated anyway 🙂 Kind of, for those of us that wish to stay in touch and continue to learn from each other in case the forum ever dissappears then yes i suppose so . I  hope that you would also count yourself in , what we learn from you is invaluable,  how you benefit from that exactly I'm not sure, being able to teach ? I did say is it ok to ask mark for some input John and suggested that he might read the thread that explains how some of us feel. I dont see how its really discussing forum policy, but in all honesty i wish i had never even bothered now.
