Witschi watch expert manual
  • 4 weeks later...
For anyone that's curious about what witschi timing machines are like the first link has demonstrations you can download. Seating kinda play with the buttons and see what things are supposed to look like.
Then there's actually four generations of the watch expert. First three generations the case looks identical except color. Enhancements added to each generation improving things. Third generation has a backlit screen which hopefully makes it much easier to see. The second-generation screen is a really shiny and reflects everything like overhead lights. Fourth-generation the machine below is basically an entirely new machine.
So first link demonstrations and the Witschi Training Course Which really is good for anyone with a timing machine.
http://www.witschi.com/en/service/downloads/instruction-document.html
http://www.witschi.com/en/group-of-devices/measurement-of-mechanical-watches/watch-expert/watch-expert.html
  • 4 years later...
Witschi timing machines are interesting versus the Chinese. If things are perceived to be out of range the witschi machine will give a variety of error messages and then refused to do anything. If it's a Chinese machine it typically will not give an error and will try to show something whether it's right or not.
Then it be helpful to know which watch are you timing and a picture of the display in manual mode when it's running as you perceive correctly.
In auto mode the machine will attempt to figure out what frequency watch you have. In auto mode it has a limited number of frequencies it will look at basically the standard. If it perceives its outside of that then you get the error message. This is where in manual mode you select like 18,000 it now knows what it's trying to time and it will time it providing its within the range of what it can do. Simplistically it's telling you it's having a problem that needs help which means there's probably some issue with the watch perhaps.
This is where it be nice to have something this machine does not have a oscilloscope. But you can also listen to it and see if it sounds right. Because anything that sounds incorrect might be upsetting the machine anyway.
Then sometimes If things get really bad you can go to rate only it won't display amplitude or beat But usually that solves the problem if things are really having issues and you still want to display something.
Then I'm attaching the PDF of the users manual
witschi watch expert II user manual.pdf
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
