I went to the library and was looking through the small section of watch books they had on the shelves when I came across a Hamilton Odyssee 2001 from around 1968 - 69 .                      I immediately thought of the Stanley Kubrick movie , " 2001: A Space Odyssey ", and found out that indeed this watch has a connection to the movie .
http://shop.1025vintage.com/products/hamilton-odyssee-2001
http://thewatchspotblog.com/?p=4890
When I saw the watch in the book it grabbed me and I knew I had to have it . I guess luck was on my side , because when i got home and searched for it I found one up for sale on Ebay with a BIN price or make offer . I made an offer that was $225 less then the asking price and forgot about it . Two days later I got a message that the seller agreed to my offer so we made the deal . There are 2 versions of this watch that were made and I got the second version . The dial , hands and bracelet are a bit different . On mine the hands have serrated lines the length of the hand and the buckle matches this design .
The case back is stamped with the Fontainebleau logo that Hamilton had a series of in the late 60's and early 70's .  I decided to do a service on it and wad fortunate to find the watch featured in " The Watch Spot Blog " where the author was kind enough to pass on the trick on how to get the movement out of the case . That information is in one of the links I've attached .
This is an Automatic winding watch that has a Hamilton Cal. 64 movement which is actually an ETA 2472 movement . A very well made movement that lined up the parameters on my timegrapher perfectly .
I can say that I am very pleased with the appearance of this watch and that it is very comfortable on the wrist .
Edited by ricardopalamino
19 minutes ago, jdm said:
Nice helmet look, if it was in my hands I'd take it as a polishing challenge emoji4.png
Thanks jdm ,
I lightly sanded , [600 , 1500 , and 2000 grit ] , and polished the crystal and lightly polished the case this morning . The crystal came out super and I don't want to over polish the case and lose any edges . I didn't use my buffing wheel because of that .
It really does look nice in person  .
I've found that the "ruining edges" issue is vastly exaggerated. Just use the proper compound and avoid edges as much as possible.
Howzit jdm ,
                  I have done that in the past and have really improved my buffing and polishing skills after watching the Youtube video ,"Introduction To Buffing & Polishing - YouTube " by perplxr .
I am satisfied with the finish on my watch so I'll leave it . Honestly . It looks good .
Aloha , Louis
I saw that thewatchblogspot Hamilton while looking for something else, have to keep my eyes open for one, since I mainly search in piles of junk for good watches, very nice!
Here is an example: See the GS?
Which GS ? ....
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
