Hello,
I have this Hamilton Military watch that I plan to service when I get my workspace together, but I'm not sure how to open it.  I'm attaching photos so you can take a look and give me some insight if you know...  Thanks in advance!
Yes , it does look like a screw on back with a Swiss type of design . A Rollex type of case opener may work if you have one but I would try a rubber ball type of opener first . You can open it with a Jaxa tool but I would hesitate because of the possibility of putting a nice deep scratch across the back . Proceed with caution if you use this method .
  Another thing I have done in this case if the back is too tight for the rubber ball to work , is to epoxy a nut putting some epoxy on the perimeter of the nut and some inside the nut , about 3/8" size , on to the back of the case and wait a day for the epoxy to set up . Then after placing the watch in a case holder , you can use a wrench to turn the back off using just a small steady pressure with the wrench . I usually put a drop or two of fine oil on the thread section of the watch , tap the case a bit so the oil can travel down the threads and leave it alone while the epoxy sets up for a day .
  When the back is screwed off you can use fingernail polish [acetone ], to dissolve the epoxy and not harm the case back .
Edited by ricardopalamino
57 minutes ago, rodabod said:
Screw-on back. Of you have a Jaxa style opener then use the flat bits.
Thanks for the help.  I thought about this, but I was afraid I would scratch the back.  I may try it, though.
I'll try the rubber ball... I didn't know if it was a screw-back or not.  I don't have a wrench that seems to fit.  I hope I don't have to resort to the epoxy, but I just might.  Thanks for the tips!
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
