Beat error
BUSAKAZ
Hi all, I'm a bit confused as to why the beat error is so far out when the pallet fork is dead center to the banking pins and the balance is at rest under no tension, can someone please explain.
thanks kaz
Ps I can't seem to regulate the rate neither,I have demagnetize it three times and the hair spring isn't touching the cock neither.
30 minutes ago, frenchie said:
Just a guess: Low amplitude and running fast = not enough power to the train (or lots of power being wasted, ie dirty jewel holes)...
it's had a new main spring and the train runs freely without the Pallet fork in, a bit confused :wacko:
I think beat error is your least problem at the moment. 5ms can be better, but is not an issue.
No wonder regulating is difficult: your hairspring is not concentric in the pins area, and it has a kink at the regulator pins. Also the pins are too wide apart, space must be minimal here (unfortunately this will speed up the rate).
Yes, as mentioned before, amplitude is much too low (which esc. angle did you choose?)
Regards,
Frank
Edited by praezis
Regards,
Frank
do the pins have to be nearly touching at the bottom then ?
it's on automatically and came up at 52deg as do all of my pocket watches, where do you see the kink after the pins or between the pins and the stud.
thanks for your help
Edited by BUSAKAZ
pic
Hi,
the kink I see in your 2nd picture, maybe I am wrong.
Pins are better, but still not close enough - and they should be parallel. Difficult with these rather thick pins, I know. But these are subtleties that you can fix later.
Main issue is the low amplitude.
52° is ok for nearly all wrist watches. Pocket watches have smaller angles, about 40°. Bad news: Your amplitude is probably 20% lower than your display shows, as the esc. angle was set too high.
Regards, Frank
8 hours ago, praezis said:
Hi,
Regards, Frank
I don't think they should be parallel if you look at the second picture at the top of the pins there is a clear gap, I will get them closer and see what it does then, I can't see a kink though and I will also try 40 deg.
I have noticed this too i.e. the roller impulse pin seems in the middle at rest but when running & put on a timing machine the beat goes out. I guess there is some sort of uneven bounce happens & that is what throws it out but i am not sure & I have just adjusted the beat.
The beat error on your watch will have to be adjusted by moving the hairspring collet & Mark has a vid on this. The rate is adjusted buy in effect shortening or lengthening the hairspring. This works by the spring vibrating in-between the regulating pins so if the rate is not changing then the spring is not in-between the pins. It is worth noting that at rest the hairspring should be in the middle of the regulating pins & not touching them.
PS. Looking at your pics there does not seem a lot wrong with the hairspring shape. Another thought is it a new hairspring fitted ? if so it could be too short.
I have a video how to determine the correct lift angle. You have to notice the amplitude and set the lift angle on the timing machine until it shows the real amplitude.
It seemed to me that the overcoil is higher at the regulating pins than the stud. This wont allow the overcoil to wobble between the pins and bend the hairspring. Try to elevate the stud a bit.
Check also again that the overcoil is not touching the cock. Just twist the balance to ~300 deg. amplitude with a toothpick. This is suspicious, since YOu have both low amplitude and beat error despite the properly positioned impulse jewel.
top man I will give it a go as soon as I can.
22 hours ago, clockboy said:
Determining the lift angle & setting the timegrapgher to correct setting will only make a marginal difference to the readings. I very rarely bother to adjust from the standard of 52 deg.
you are correct changing the lift angle made absolutely no effect but what I have done is closed the pins in a bit more and I had the train bridge to tight so slackened it off and the amplitude has now shot up.
also I straightened up the spring from the pins to the stud so I am now thinking how to get the rate down and I is definitely not touching the cock, but it is getting better and it is still the original hairspring.
still need help, it a southbend 411 12size but if anyone knows the lift angle that would be good.
thanks for your help guys
If the bridge is causing the hairspring not to swing either the bridge is bent or the balance staff is too long (marginally).
I strongly suspect a new hairspring & balance has been fitted but the hairspring is just to short. There just does not seem enough of the hairspring remaining to reduce by 130 s/d. This PDF explains better than I could.
Hairspring choosing.pdf
I think I have found the problem, if you look at the hairspring at three o'clock the spring is touching what do you think.
Also, you have not mentioned whether or not the movement has been fully cleaned and lubricated?
A reading like yours generally points to the escapement, in which case a full examination of the balance assembly (bridge, staff, balance wheel truth and poise, roller table, impulse jewel, hairspring, collet, regulator pins, stud), pallets, lever, escape wheel and jewels must be conducted to locate the error.
fully cleaned and oiled with moebius 8000
    • You would always get an answer John, you dont need to be dramatic or humerous to get one, but it was appreciated anyway 🙂 Kind of, for those of us that wish to stay in touch and continue to learn from each other in case the forum ever dissappears then yes i suppose so . I  hope that you would also count yourself in , what we learn from you is invaluable,  how you benefit from that exactly I'm not sure, being able to teach ?
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
    • For me any input from Mark would be great. If he's keeping a close eye i would imagine he has read about our concerns here. But specifically i would like to know if he is ok with us collecting each others contact information for those of us that wish to provide them.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
