Omega Wig-wag screw?
rogart63
44 minutes ago, SSTEEL said:
Sounds like you have sorted it, hopefully a shorter correct screw fitted all will be good, I ~have encountered similar whereas a too long screw had been fitted by someone else, in my case the screw was touching the main spring barrel, causing the power reserve too bind up.
This movement  have been worked on by a lot of of different people. Parts have been lost or broken in the process.
  • 4 weeks later...
Hey @rogart63,
I am posting here on your question about the dial because I couldn't insert photos using the messenger system.
Here are pictures of the dial spacer for the Omega 1020 family of calibres
DSCN4849.jpgDSCN4848.jpgAs you can seem, it goes directly on the dial and sits between the movement and creates a small space between the dial and the calendar mechanism. If you don't have this in place, then that is the reason the movement stops working when the dial is on.
JC
Edited by noirrac1j
