Hi all, greetings from sunny South Africa.
I'm looking for some advice on pall setting/alignment methods used for bulova accutron or eta/omega 9162 or similar movements. I have been serving / restoring these for a few years now and it's always a pain to align/set the alignment.
If anyone could point me in the direction, or know of any documentation on official service procedures I would be greatly appreciative.
Regards,
Jason Mauer
Hello Jason and welcome,
I saw Georges reference and have PM'd you a list of PDF's and a site reference, hopefully there are no problems.  I am in the process of creating an Accutron entry for the PDF / Document library and once Mark is back from Holiday he is amending my permissions to set it up and add other documents I have obtained in the public domain.
If you have been servicing them for a few years doubtless you have come across info I and others will be interested in.  I had difficulty up to the point where I bought a stereo microscope with 70x mag which was the the point where I was able to set the "draw" and phasing the accutron was more viable ie I could actually see the teeth on the index wheel.  I know others have managed with other types of magnifying devices but my eyes are not up to it. The site I referred you to:-
http://members.iinet.net.au/~fotoplot/acc.htm
is a gold mine of information and you could do worse than reading through it.  My thanks go to Rob Berkavicius and his co-writers for providing so much valuable information that set me off on the right path.
Cheers,
Vic
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
