Seeking Jaguar expert advise.
Hi guys,
I was looking for a first car for my youngest daughter, who starts college next year and I've found this one so, I figured it wouldn't hurt to ask this questions to the mechanics and mechanic knowledgeable people in our forum:
What is your opinion about an S-type Jaguar, 2005 with 114000 miles?
What would it be worth considering it looks in pretty good condition?
The owner said the dealer changed the transmission and the dashboard gauges (?) and it is still within the 1 year warranty.
Your input is really appreciated!
Cheers,
Bob
Thanks Vinn, but as I said, the transmission is already repaired (exchanged) by the dealer. In any case, she won't be able to drive stick shift anyway...I'm stuck with autos no matter what I choose!
I'm just a little put off because of the age and high mileage...any advise or comments? Thanks!
Cheers,
Bob
S-stype Jaguar are essentially Ford based. They are better than X-type, stay away from X-type as they have issues. The best are the XJ8 from what I have seen. The s-type should be fine considering that the trans was just replaced. Make sure you as for paperwork to prove the work was done though.
The XJ8 have BMW transmissions, but they are about 1500-2000$ to replace if they go bad.
The S-type from what I understand is a ford taurus based model from the particular generation that Bob is looking into. The XJ8's from 97-2003 have BMW seven series trans. The only difference is that one piece of the trans (I forget which) is mounted on the opposite side for the Jag, so a straight swap from a BMW is not possible.
Thanks guys, that's very informative. I don't really like Fords! Yes, I'll request the trans paperwork if I decide to go that route...Have you heard of any electrical problems or anything this car may be prone to show?
Cheers,
Bob
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
