Chinese Hand Wind
Used alot this is a Chinese movement out of a rotary skeleton 20160528_110512.jpg
It's only a very cheap movement but I am looking more to the Chinese considering what the Swatch watch company is up to. I don't have an ETA 2824 movement but I do have a 2841 which is basically the same movement without the date and hacking feature, which is really nice. But I've heard the Chinese 2130 is every bit as good and about 75% less the cost to buy.
curiously enough I have just serviced one of these in a Rapport pocket watch for someone. It wasn't too bad quality wise but the general fit and tolerances were not as you would expect on something Swiss and this did reflect in the performance of the watch.
As far as multiple train bridges are concerned this is a fairly common arrangement, particularly with train layouts that are a little less conventional. Again, just off the bench I have a Sekonda from the 70's powered by a Slava 2428. Now there's an unconventional set up of ever there was one; 2 main springs, funny side ways pallet, date quick change arrangement built into the movement ring... and 2 separate bridges for the train.
I shall have to put it together as a walk through when I get the time.
Still mucking about with this movement. It fascinated me with one train bridge on top of the other . The whole watch , movement, case and strap cost £10 brand new. The time keeping was awful, with a complete scattered pattern on the timegrapher. I stripped it down, oiled it and reassembled it. Just regulated it even with an unacceptable low amplitude. Better now but not perfect. See pics below. I think originally the hairspring was hitting the seconds wheel.
Anyway was either doing this or jobs around the house this afternoon. No contest really.5171bed2f78098b431ee99d4c099e827.jpg93f302107f675ec0732c2454d357777b.jpg
I'll take watches over chores, unfortunately, sometimes they are equally challenging, you have the patience of a saint....:thumbsu:
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
