U.S. Shipping Board
TimFitz
Just completed a cleaning of a watchcase & a Waltham 15j Pocket watch movement.
Then I put them together to make a whole watch. Neither came to me as a whole timepiece. I have been looking for an unusual case to put the movement in & I found it at Dave's
watch parts.
The movement was very dirty and very sluggish & the case was very tarnished with dings and scratches. The crystal was not bad with a lot of small scratches (fixed with cerium oxide)
So here are the before & after shots
It is interesting... Walthams were manufacturers of movement's. To my knowledge they never sold watches.
They would retail to Jewellers etc. It was normal practice for a customer to pick a case and select a movement. Then the Jewellery shop would fit movement to case. So really the "watch,being the movement " was never supplied in an original case, as is the practice today.
That's why you could have a Waltham in a case inscribed say 1920 but the movement could be 1916 but it is the case it was first fitted into.
All you've done is something similar to original practice of 100 years ago.
The point I'm making is Walthams never supplied cased movements so are any Walthams truly original by definition.
1 hour ago, TimFitz said:
I realize some people are down on re-casing, however there are tons of movements & not as many cases. I think re-casing for a personal collection & not for resale is the right thing to do. Now I have a beautiful watch to use and admire.
I'm going to put black lacquer in the engraving, to make it show
I can't see any reason if you were to sell, it wouldn't reach a high price with the work you've done. It's obviously a re-cased movement because you've fitted a hunter movement into an open face case.
I own many Walthams and due to the nature of the trade as previously mentioned, there's no way I could be certain they are in there original cases.
Most modern manufacturers use trade movements but they leave the factory cased. So originality is easier to identify.
    • Have you now repaired it? If so how is the time keeping.
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
