Felsa 690 mainspring
avion
Hi
If you're familiar with the Bidynator movement, I would appreciate your help!
The break spring on my Bidynator looks different than the one in this post:
http://forums.watchuseek.com/f6/felsa-690-auto-mainspring-1021404.html
Mine doesn't have the additional "tongue" (this extra piece of layer) see photo please:
There is a tiny notch where the tongue appears in the other post. So maybe it was there once.
What do you think? Is it missing? Could It work without it ?!?!?
Thanks !
Ron
So your photo really isn't doing anything for me as it doesn't look like a mainspring? So looking up the watch you have it's an automatic. The link you had talked about it originally was a two-part mainspring. Today they come as one piece which should work fine, I have several listed below.
MSS-WA40 1.45 x 0.11 x 312
Generale Ressorts  3984-X  1.45  0.11  340
Zf1044, 1.40 x 10.5 x 0.11 x 350mm
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Felsa_690
Yes. It consists of a breakspring and a mainspring. Problem is that the inner barrel of that movement is smooth. So I find it hard to believe that it would work with a "one piece" spring. Are you certain?
Your mainspring barrel wall is supposed to be smooth. So automatic watches require a mainspring that slips it cannot be permanently attached to the mainspring barrel otherwise the automatic will wind up to the end bad things will happen. So to solve that problem the mainspring has to slip. Thoroughly watches the slipping part was a separate spring with a hook that a standard spring would hook to. Then later on they made it all one spring with various ends that slip. So as long as it's a mainspring of the right size for an automatic it should work. Then make sure you use the right type of breaking grease for the barrel.
I consider this kind of interesting. The bridle must slip at the end of winding, but one should to use braking grease to let it grab at all other time, apparently the two things are contradictory.
Maybe Nomos did the right thing on their latest auto movement, no slipping. The rotor stops when the spring is fully wound.
Breaking grease interesting substance. So it needs to hold the end of the mainspring until sufficient forces developed to allow it to slip or bad things will happen in timekeeping but it can't slip prematurely as that's equally bad. Then when it does slip it has to be a very high pressure lubricant so you don't grind the barrel itself.
So I have a link to various types of breaking greases unfortunately it does not talk about applying them as the quantities may be different and how they are applied and how to test that the breaking greases actually working.
Then the video shows what happens if things don't work right. Then when he's examining the barrel wall notice it's not smooth? Like everything else in watchmaking there is lots of different ideas not all mainspring barrels have smooth walls.
https://www.youtube.com/watch?v=7KNTrHVD088
http://hiro.alliancehorlogere.com/en/Moebius_8201.html
Nomos I be curious to see an image of how they stop the rotor. It's not entirely a new idea automatic watches have lots of innovative things. For instance LeCoultre 497 Also stops the rotor when it's fully wound. Has an up down indicator so you know if it's wound up as there is no manual way to wind the watch.
Maybe (I don't know for sure) they simply count on the fact that the very small torque of the rotor, which is only active for fractions of seconds, can't break the mainspring or any other winding component, which according to them are build with special materials http://www.nomos-glashuette.com/the-movements/automatic/duw-3001/
    • As much as I hate Facebook, can a forum-like place be set up on there? Free and the ownership can be taken over by the next person whenever.
    • I existed before the term mechatronics engineer existed. I had to combine electricity, electronics, pneumatics, hydraulics and computing just to keep my own equipment working. I have never sub contracted any of my own repairs to the suppliers because I know I could do a better job. For a long time, dental suppliers in my country would bring their dead equipment to me that their own engineers cannot handle. I have accidentally embarrassed a couple of hospital heads of engineering by demonstrating their inadequacy.  I think mechatronics is the most under-appreciated, under valued of all the engineering sciences. I had a part-time dental assistant about 25 years ago, who was studying mechatronics in the polytechnic. She was absolutely clueless about the job prospects for a mechatronics engineer. I asked her about her aspirations and she replied that she really wanted to work in the games industry.  In our dental profession, equipment have evolved from simple mechanical to electro-mechanical to logic-driven electro-mechanical and currently to computer driven machines.  The medical equipment suppliers who employ mechanical engineers and/or mechanical engineers cannot cope with the repairs of the newer equipment. And many times end up changing whole modules and whole machines just because they cannot repair them. But I think HR is afraid to employ a mechatronics engineer just because they don't know what a mechatronics engineer does. Mechatronics is much more fun. It combines almost all of the engineering sciences and produces an all-rounded engineer. But until HR changes their mindset, not all door will be open.
    • Welcome Tarheel, there is a lot of help on this forum...
    • Hello and welcome to the forum.    Enjoy
