ETA 2836 issue
27 minutes ago, Danh said:
i will get a tool and try all that
The ETA is not really indispensable, the regulator pin turns easily with tweezers. Also, is used for positional adjustment, but you have to eliminate beat error first. If you have less that 15 s/d positional variance don't even bother messing with it.
9 minutes ago, matabog said:
nice!
I didn't notice the beat error before...
I am hoping tomorrow night when I have more time to follow that tutorial you posted, very interested in that. For me "doing" promotes my understanding, if you know what I mean
That's a fair comment Matabog, maybe just finish the assembly of the watch then.
i have another 2836 in bits at the moment, waiting for a pallet fork to arrive from Spain - hopefully that will turn up soon
Don't get me wrong, it is awsome when you make it work but it is terribly frustrating when you brake it.
Let's face it - we are playing. People go to school and learn this stuff in months, if not years and practice after that....
but then... No pain, no gain :) you got to learn somehow... the most important stuff you will learn from your own mistakes ;) I know I did (and still am...)
Edited by matabog
1 hour ago, Danh said:
Took your advice JDM, stills bit more to do on it, but it's getting there, and I am learning loads
Wonderful. I have one more advice from experience about movements that are slight slow like this. Observe it over 24 hours, fully cased, and in various positions. if stil below 0 s/d on average make run it a little bit faster, nobody stands watches losing time, but if it gains that's tolerated.
That's good advice JDM, when it was on the timer (which handily rotates with the watch locked in place I noticed), I tried that quickly tonight and noticed the numbers changed when the watch was rotated 180 degrees.
i think it slowed it down by 10-15 seconds per day, but was being shouted so had to stop what I was doing.
i am going to start testing tomorrow night
thanks again Guys
2 hours ago, avion said:
I gotta say. That part when you fixed the hairspring yourself, considering that was your first time, is kind of incredible.
Thanks Avion, but I have to say the student is only as good as the teacher, Marks Videos are brilliant, and very well filmed for the close detail
Thanks for all your answers and help folks, the watch is now assembled and in testing - my first complete job as a total service, repair, made a Horween leather strap for it, and cast a sterling silver buckle and aged it.
i wanted an authentic look close to the 1940's version, but with an automatic movement
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
