Fixing Hands
Hello,
I got this watch in an essay contest many years ago, and it got put the the washer and dryer a few years back. Im wanting to try to get it running again. As far as I can tell the second hand has just came off (broken off?). It's not running either, so I hope its just in need of a battery. Any guidance, advice, tips or direction would be greatly appreciated.
Please and Thank you
The first thing you need to do is open it up and look inside at the movement to see what damage has been done. It looks like a flip off back so that shouldn't be a problem.  Post a photo and we can guide you on what action to take. In some cases a complete replaceable movement could be the least expensive option.
Look very carefully with loupe or magnifying glass to find out cal or movement number, looks like a miyota, PCxx?? (used in most inexpensive quartz), once you have determined movement number, just search on web, lots of new movements relatively cheap from supply houses, (gaskets too) there's a small button or detent to remove stem/crown, press with sharp pointy object and pull out stem, once stem is removed, entire guts can be removed, now it's about taking off hands and dial, warning: some of these dials are glued on during assembly process, can be like surgical procedure to get them off without damage!! I have done more than a few of these and it's nice to have something that you have fixed for remembrance.
If it's been through the wash, chances are movement is 'toast', but who knows, try a batt, you'll need it for the new movement anyway. Update us with your efforts and if you need any more help, good luck!
Thank you for your input! Originally I had started this post to get the hands put back on, I got that and got a new battery and it was good, then it started either losing time or stopping/starting, so now I figured I would just attempt a replacement.
So, as far as the part number goes, I can read this: No Jewels Unadjusted/Japan/S110/PC21A
I found a few matches for that on Esslingen.com, but it looks like there are a few different ones by the same #, any advice?
It's a Hattori, readily available and inexpensive. As long as it measures the same as old one (Height and Width) and dial legs/feet match up it should not be a problem. Esslinger is a good source. Cas-Ker Co also stocks. Remember there may be some adhesive under the dial, so be gentle when attempting removal.
HATTORI PC21, 17.8mm x 15.3mm, Height - 3.15mm, Battery 377
DIAL FEET  5:00/11:00/7:00/11:00
Your gasket looks okay from pic, (to me)
Good deal! Found the movement, and I I'm going to get an assortment of gaskets ( it looks ok in the pic but it was actually in half a dozen pieces).
and there was some glue but not bad, I got it off without breaking anything. That being said, I do wish I had just found a pro to take care of this. If hate to mess it up now.
Let you know when I get it finished. Thanks again
on Esslinger's site, this movement calls for:
  • Requires watch hands: hour 1.20, minute .70, and sweep second .17 mm
Is that a typo, because those ratios don't look anything like what I'm finding in their watch hand kits...
I got my order today: movement, hands, crystal, gasket, hand inserting tool etc.
Once I got it assembled I couldn't get the stem to wind to set the time. The stem turns, but the hands remain stationary.
At one point the second hand ticked, then it starting just jumping back and forth in one place.
What would cause that?
Is the stem engaged fully, (pulled all the way out?) I like to put batt in and replace second hand before recasing, just to confirm operation. Is it possible dial is making contact with hour/minute wheels? Preventing them from turning.
It's tricky to get hands aligned properly and set on wheel(s) so they turn properly and don't catch each other. I think Marc has video on this site for hand installation,  granted it's for a different watch, but theory is still the same. Guessing.... but second hand may not be tight enough? or too tight?
OK it's officially finished! I took it to a watch repair shop in the mall. Apparently it was a combination of improperly inserting the hands and the hands being butchered to heck. 20 minutes and $20 later, good as new. Ironically the hands were the original problem, and the only thing I had to take in and pay to have done. I did get some simichrome and polished it up and put in a new crystal.
I definitely have a greater appreciation for the craft now, thanks a ton for all the advice and info!
Good for you! It never hurts to have a 'pro' look at something that has you stymied as long as they don't want to charge you up the wazoo for the privilege. Often valuable info can be gleaned from inquiry. Many time jewelry stores, who send most everything out to watchmaker, will quote exorbitant prices for quartz swaps, look at how much your total cost to redo this watch and weight that against your willing to spend to have someone else do the work. For the $20 you spent to have hands set, (not including movmt, glass, gasket, etc) its probably worth it. I hope this experience will encourage you to take on future projects.
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
