Now I don't blame the seller for this, but a glued on dial?!?, I knew it the moment I opened case, but was able to very carefully pry away dial with xacto blade. (thankfully cheap glue!)DSCF0168.JPGDSCF0169.JPGDSCF0170.JPGDSCF0171.JPG
 One mismatched 23 jewel in a 17j case! (BONUS), this is why I always look for case/movement/dial numbers or ask questions if pics are not clear. All three were listed parts and repair, so for $20USD + $6 ship, why not?  The glued dial is running and the "TV looking" case is a 6309, (17J) in a 6349, (23j case), I think I will correct. Oh and found a phantom screw, not from movement, hanging out under balance, once removed, she started running. All in all not a bad weekend, two out of three runners and 23 jewel to boot! BTW it has badly handled hairspring, probably replace entire balance.
6309 and 6349 is that the same movement? Only more jewels in the 6349?
Have an ugly but repairable 6309 with white dial you could have if you like?
The dial and hands are okay. The chapter ring is a little damaged? but could maybe be found or polished.
Post a picture later.
Edited by rogart63
pretty close ( don't know for sure but side by side they look same), my 6309 is running I forgot to mention, the glued dial is a 7009, thanks for the offer. All these numbers are confusing!
Dave
Interesting. Probably an updated version with jewels in the train wheel bridge and  main plate? Will look into it.  A 7009 i don't have? This was the 6309 case with dial and hands.
It's not uncommon to open up a 6309 case and find a 6349 in there.  I think that maybe  the 6349 is an earlier model.  Either way,  they are both a fairly robust movement.
Thanks Ramrod, I ordered balance complete from Israel, (of all places), try to post up pics when repaired. If I remember!
okay got balance, installed and not functioning, think the escape is not fully engaging, I did not take down entire movement, so that's in the future, the balance complete did not have a collet at end so I figured spring had to be aligned inside small keeper at end of cock and tighten with screw, ( I could be wrong but I though I saw similar setup on other Seiko) I'm in midst of house siding remod which is taking up most of my time, so if I don't get back soon, you'll know why, pic is bit blurry and parts at right are from recent purchase from the bay, I was parting out, That Philippinean guy, via Redmond Washington, got a decent 7s36 dive watch complete for $14, that one is working but only for a few hours. ANOTHER PROJECT!!!!! Thanks for your interest.DSCF0192.JPG
  • Similar Content
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
