Help with ISA movement
Hi, I'm trying to locate an ISA J320 movement in the UK, with a calendar at 6 o clock. Cousins sells the movement, but only with a calendar at 3 o clock. Is there an equivalent, or could anyone suggest where I could get this movement?
All help greatly appreciated!
keith
Thank you for the reply. I am looking for the whole movement and in answer to your question, does it mean that although the calendar on my watch is at 6, I can still order a movement with a calendar at 3?
as you've probably guessed I am a beginner, but I have replaced a few movements before
thanks again for any help, keith
Apparently the j320 is the same as the 330. I searched for the ISA-330 and Time Connection Inc has it listed in their catalogue, with the date at 6 (iSA-330.103-D6, page 39)
Disclaimer : I'm not related to anyone at Time Connection Inc and have no idea who they are. I just found them when through a google search for said movement.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
    • Ohh spooky I have just aquired the same one mike, but mine has a drill bit inside it.
